Old 02-04-2020, 03:47 PM   #1
flatheadmurre
flatheadmurre's Avatar
Default How bad can it be...the tale of a -41
Have a good laugh at my expense !
So my dad bought a -41 on distance.
Seller said it needed upholstery and that he drove it in his driveway last year.
So how bad can it be...
When time for picking it up arrives the seller offers a free donor car to go with it...hmmm
Back in MN trailer hooked up and backing into sellers driveway the car is pieced togetter from more then one for sure and has flatblack primer over sandingmarks...
Ok it was a bit rougher but it runs...how bad can it be...
Trying to start the car it turns over but doesnīt fire at all...brakes is nowhere to be found...seller points out he has installed a brand new tank..
Yes i can see the tank through the trunkfloor...
Frame looks good...and nothing else should be a structural issue...fixing a flathead is not going to be a to big headache...how bad can it be...
Fastforward back to sweden...starting to poke around the coil donīt even have a brush in it...ran last year...not to sure about that.
Carb, fuelpump and distributor rebuild later the engine fires up and runs fairly well with good oilpressure...small victory dance !
Turning drums fully rebuilding brakes.
Swiping a blanket from wifes stash and making a 30sec upholstery enough to sit in the car and take it for a testdrive.
Clutch slips...gearbox kicks out of second instantly when letting go of accelerator...
Out comes the engine and tranny...new clutch rebuilt gearbox...how bad can it be...
Fixed the speedoturtle...a bit of wiring...some more hillbilly upholstery...out for a drive.
Rear howls like a pack of wolves at deacceleration...at this point getting it through inspection before any other rebuilding is made top priority.
Cause at this point how bad can it be...
Itīs cold here so installing a heater that works great...for about an hour until the core starts weaping...out it comes again...new core...back in again...iīm starting to become a -41 pitcrew.
Off to the inspection...drives nice as long as the foot is down keeping the wolves away...at inspection the usual stuff, they canīt figure out how to start it get it into gear...but once up on the brake tester it starts to look better.
Brakes emission front/rear supspension passes with flying colours...another victory dance !
Then it start going south fast...guy looks at the rockers and says they are rusty...yep i know...but the car has a frame !
Now 2 people are scratching their heads...then they come up with that the side impact collision safety is affected by the rust...WHAT ???
Now i know how bad it can be !!
Tomorrow i will start fixing the side impact collision safety system...
Old 02-04-2020, 04:18 PM   #2
JSeery
JSeery's Avatar
Default Re: How bad can it be...the tale of a -41
Got to love folks that know very little about ventage vehicles telling you about what it takes to make them safe.
Old 02-04-2020, 04:36 PM   #3
Mart
Mart's Avatar
It just proves it's all fixable.
In the right hands.
An interesting tale. I hope it has a happy ending.
Mart.
Old 02-04-2020, 04:44 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
THIS car had a bad "FRONT impact collision safety system!" DD
Click Links Below __
T5 W/TORQUE TUBE
Old 02-05-2020, 07:54 AM   #5
corvette8n
corvette8n's Avatar
Sounds like your fixing everything as it comes up, post some pictures as you continue on this adventure.
Old 02-05-2020, 03:05 PM   #6
Brian
Brian's Avatar
I always thought the running boards 'were' the side impact collision safety system! lol
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 02-05-2020, 03:21 PM   #7
tubman
tubman's Avatar
Murre, Did you get that car from Leo by any chance? From your description it sounds like something he might have!
Old 02-05-2020, 03:52 PM   #8
flatheadmurre
Nope Leo is not responsibe for this one...It was Mr mercury that found this one and the rest is Douglas wheeling and dealing...i just ended up with the CPR task to bring it back to life...iīll get some pics tomorrow of the new side impact system.
Very crude...just bent profiles and sheetmetal.
Old 02-06-2020, 03:00 PM   #9
flatheadmurre
Passengerside back in one piece...more or less
Passing inspection first then descisions about evicting the wolfpack and interior upgrades...
Old 02-06-2020, 03:15 PM   #10
tubman
tubman's Avatar
Love the upholstery! But what happens when your wife finds out where her sofa cover is?
