Old 08-31-2017, 04:25 PM   #1
Royal Ryser
Default Which holes to mount 36 tudor radiator?
Does the 36 radiator mount in the front or rear mounting holes?
Thanks
Royal
Royal Ryser is offline   Reply With Quote
Old 08-31-2017, 05:15 PM   #2
Don Rogers
Don Rogers's Avatar
Default Re: Which holes to mount 36 tudor radiator?
Rear holes for 36 passanger car.
Don Rogers is offline   Reply With Quote
Old 08-31-2017, 05:59 PM   #3
Royal Ryser
Thank you, Don. I thought so, but am having trouble getting the front sheet metal to line up. Others have, too. I'll keep at it.
Royal
Old 08-31-2017, 10:37 PM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
Royal, I'm thinking someone once sent me some detailed instructions on 36 Ford passenger car front end alignment. I'll take a look and see if I can come up with this if you are interested.
John
Old 08-31-2017, 11:10 PM   #5
Royal Ryser
JM 35 Sedan, thanks for any info you might come up with. I'm pulling my hair out and have none to spare!
Old 09-01-2017, 03:37 PM   #6
Rusk
Rusk's Avatar
Try this...
https://fordbarn.com/forum/showthread.php?t=8199
Bryan
Rusk is offline   Reply With Quote
Old 09-01-2017, 08:23 PM   #7
TagMan
After many, many frustrating hours of trying to fit the front end sheet metal on my '36 coupe, I found that small adjustments on the radiator support rods can do more than anything else to line things up perfectly. It can be done ! The guys in the factory did it in a few minutes.
TagMan is offline   Reply With Quote
