Old 03-30-2016, 07:16 PM   #1
CWilson
CWilson's Avatar
Default Battery/Charger/Alternator
I messed up somewhere along the line I think. Is it possible to have a 12v neg alternator and a 6v battery? (Cause that's what I have set up right now) The 6v battery explains why my 12v battery charger wouldn't charge it.
CWilson is offline   Reply With Quote
Old 03-30-2016, 08:31 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Battery/Charger/Alternator
I would disconnect the wire from the alternator then check the alternator output voltage and which way it's grounded. Either match the battery to it, or change the generator/alternator to match the battery.
Old 03-30-2016, 08:48 PM   #3
CWilson
CWilson's Avatar
Alternator is stamped 12v neg.
Old 03-30-2016, 09:28 PM   #4
Tom Wesenberg
But some have been switched to 6 volt positive ground and had a label applied which may have fallen off.
Old 03-31-2016, 01:17 PM   #5
CWilson
CWilson's Avatar
What happens if you have a 6v battery and a 12v alternator?
Old 03-31-2016, 02:20 PM   #6
Willie Krash
Willie Krash's Avatar
Your car will smell like rotting eggs as you drive. You'll gas the battery. Might even blow it up, or it could swell so bad that the case cracks.
Think about hooking your table saw up to 220V..
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
Old 03-31-2016, 02:46 PM   #7
CWilson
CWilson's Avatar
What if I have a 6.8v resistor on the alternator?
Old 03-31-2016, 05:03 PM   #8
Tom Wesenberg
No good!
The voltage must be regulated to match the battery.
Old 03-31-2016, 08:16 PM   #9
SeaSlugs
SeaSlugs's Avatar
suprised battery hasnt already exploded...
do what tom said about checking the output of the alternator to see exactly what its putting out. if its 12V go get a 12V battery, their like $40 from a farm store...or wait for sulfur and hydrogen gasses not to mention battery acid to come out of your battery if it doesnt blow up thru the floor board.
Ive been driving an electric cushman (has 6 12V batteries) when one internally shorted and blew up directly under my butt, thank god the seat bottom was 3/4" plywood, left a pretty big dent in the wood. Still hurt like getting hit with a paddle though. not to mention it was loud with earplugs in and acid was raining everywhere.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 03-31-2016, 08:42 PM   #10
CWilson
CWilson's Avatar
Ok, thanks guys. I'll check it this weekend.
Old 03-31-2016, 09:00 PM   #11
CWilson
CWilson's Avatar
Which wire do I check?
Old 03-31-2016, 09:19 PM   #12
MikeK
MikeK's Avatar
You have a Delco 10DN with an external Transpo transistor conversion regulator. These were made for both 6+ and 12-. From the look of the reg wire color coding it appears to be a 6+ conversion, but I could be wrong. You can still buy those regulators!: LINK
Like most 6+ conversions the set point is way too high.
MikeK is offline   Reply With Quote
Old 04-01-2016, 08:13 AM   #13
Tom Wesenberg
Check the voltage at the stud with the aqua colored terminal.
Old 04-01-2016, 11:30 AM   #14
jax55
jax55's Avatar
Ditto to MikeK.
jax55 is offline   Reply With Quote
Old 04-01-2016, 01:43 PM   #15
Willie Krash
D7010 is an obsolete number but probably 6V (D7011). It look like it is is set up for positive ground and should be adjustable.There is a pot under the body of the regulator.
Mike Stitt
-Henry Ford
Old 04-02-2016, 08:04 AM   #16
CWilson
CWilson's Avatar
I checked the voltage coming out of the alternator, and it's 6v. So the problem is that I was stupid, and trying to charge a 6v battery with a 12v charger. Thanks for the help all. I've got a 6v charger on the way.
Old 04-02-2016, 10:15 AM   #17
Tom Wesenberg
In a pinch you can actually connect a 12 volt bulb in series with the battery charger cable connected to a 6 volt battery. The bulb will drop the voltage and current to a safe charging level, but the best way is to buy a 6/12 volt 5 or 6 amp battery charger with a meter.
Old 10-05-2016, 01:17 PM   #18
41 Ford Pickup
I have a 1941 Ford pickup that is 6V Positive ground. I have a 12V charger, but I am going to buy a 6V charger.
Does it matter to the charger if the truck is Positive or Negative ground? Do you hook up the charger cables differently?
Any recommendations as to a good charger to buy?
41 Ford Pickup is offline   Reply With Quote
Old 10-05-2016, 01:26 PM   #19
C26Pinelake
Sorry pal you can't high jack a thread and you should be on the V8 forum. Wayne
C26Pinelake is offline   Reply With Quote
Old 10-05-2016, 01:38 PM   #20
Big hammer
No it doesn't matter! + or- ground! You need to determine what you have and connect the charger + to ground or - to ground
Charger positive to the battery positive
Thread Tools
Display Modes
