Old 07-02-2016, 10:46 AM   #1
CWilson
CWilson's Avatar
Default Adjusting brakes
I adjusted my brakes according to the Red book. So much better. When I stomp on the brakes going 25-30 mph, the rear brakes don't completely lock up, but there are noticeable black tread marks left on the pavement. Does this seem about right? You can barely make out the sound of the rear tires squealing.
CWilson is offline   Reply With Quote
Old 07-02-2016, 10:48 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Adjusting brakes
Sounds like you are good to go..............I mean good to stop.
Old 07-02-2016, 12:05 PM   #3
redmodelt
redmodelt's Avatar
Skidding/locking up = loss of traction = loss of stopping
Old 07-02-2016, 12:15 PM   #4
J Franklin
J Franklin's Avatar
Why won't they lock? they should, and the control for not skidding is your foot. If the wheel turns with slight drag and there is adequate movement of the brake rods they should lock. Maybe it needs another turn on the clevis or shoe adjustment.
Old 07-02-2016, 12:43 PM   #5
CWilson
CWilson's Avatar
I already adjusted one more click, and it seemed too tight. Maybe that's where it is supposed to be. Maybe it comes down to preference and driving style?
Old 07-02-2016, 12:45 PM   #6
CWilson
CWilson's Avatar
Kind of what I was thinking also, but Franklin makes a good point also, your foot is the control.
Old 07-02-2016, 12:55 PM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
BUT, J,
We don't need locking & skidding What if the road were WET or ICY?--Then they'll READ about you in the OBITUARIES---"GONE & will be remembered for 2 WEEKS"---On the plus side, you won't get any OLDER & won't have to overstress your "BRAIN", remembering stuff.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-02-2016, 02:01 PM   #8
J Franklin
J Franklin's Avatar
Maybe we can call that antique anti-lock brakes.
Old 07-02-2016, 04:19 PM   #9
Jacksonlll
Jacksonlll's Avatar
The model a is a rear skid design. The should lock up.
