02-04-2020, 03:48 PM | #1 |
Mercury head gasket question
I have not run into this before... On a 1941?? Mercury engine.
It is a 3-3/16" bore, with the early type Water passage openings (triangle on top circle in middle and trapazoid shaped bottom one) Nobody makes this gasket. Can a 59A 46-48 gasket be used even though the water passage shapes are different? |
02-04-2020, 04:11 PM | #2 |
Re: Mercury head gasket question
Yes.
02-04-2020, 04:21 PM | #3 | |
02-04-2020, 04:24 PM | #4 |
I believe an 81A copper will work too.
02-04-2020, 04:36 PM | #5 |
I assumed there would be no issue, but wanted to be sure I was not missing something.
02-04-2020, 04:39 PM | #6 |
02-05-2020, 03:15 AM | #7 | |
