11-24-2019, 05:02 PM | #1 |
1937 Cam Regrinding
Can the stock 37 ford cam be reground close to an isky max1 3/4 cam ? Or what is a good sounding cam for a 21stud motor that will have sharp heads on it. Thanks all.
11-24-2019, 05:09 PM | #2 |
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
Re: 1937 Cam Regrinding
We like the Isky 77B cam grind.
11-24-2019, 05:17 PM | #3 |
Can the stock cam be ground to that ?
11-24-2019, 05:41 PM | #4 |
I don’t see why not. I have re-ground several of those early cams to my KiWi-L100 specs.
11-24-2019, 06:18 PM | #5 |
Kiwi do you still grind them. I’m looking for someone to do one.
11-24-2019, 06:45 PM | #6 |
11-25-2019, 09:36 AM | #7 |
just curious, Does the cam you have ,has apressed on timing gear.????? Most any cam Grind can be put on a stock cam. Which brings up the application and cost. When re grinding a stock cam, you will have to use adjustable lifters, or longer valves. Also in a stock engine, longer duration reduces low end torque The 77B is very much like a stock grind$$$$$ for changing the cam you must have a good reason.
11-25-2019, 02:57 PM | #8 |
Ron I’m going with the 1007B cam. The cam I believe is the press on timing gear. With that cam it will have Sharp heads and dual carb intake. Im on the fence on the adjustable lifters, if i run them I will have to make jam nuts for them or just get longer valves and cut them to what I will need.
11-25-2019, 04:15 PM | #9 |
The 1007B is a really good cam - you'll like it in that engine! I tend to run Chevy valves - as I like the longer length. I then make custom spacers for the guides (depending on the cam, springs and how much spring pressure I want on the seat).
11-25-2019, 07:28 PM | #10 |
Curious about your Sharp heads. Are they original? Sharp 21 stud hmmmmm any pics of them or history.
Cheers TP |
11-25-2019, 07:52 PM | #11 |
Kiwi. Repop from h&h. I believe they are about 8:1 compression ratio.
11-25-2019, 07:56 PM | #12 |
Ah okay they look great but Sharp never made 21 stud heads like that. I have a laaaarge Sharp collection.
Cheers |
11-25-2019, 08:14 PM | #13 |
Well if I come across someone wanting to give up Evans or cyclone 21 stud heads instead of letting them sit on their shelf I’ll take those too. Hahah.
11-25-2019, 09:32 PM | #14 | |
Happy TurkeyDay to Yah! |
11-26-2019, 10:46 AM | #15 | |
My super popular KiWi-L100 cam originated from your great state of Rhode Island. Cheers |
11-26-2019, 11:05 AM | #16 | |
And a Happy Turkey day to yourself. Cheers Tony |
Thread Tools | |
Display Modes | |
