04-20-2016, 11:09 PM | #1 |
Starter drive bolts.
Last week I had the starter drive bolts fall out into the flywheel housing. I referred to Les Andrews Mechanics Handbook Vol 2 to read the following, "When either bolt breaks, it falls into the flywheel housing, creating a very difficult situation to remove the broken bolt".
I made several attempts to remove the bolts using a magnet without success, then I had an idea. Suck them out. The following is a link to the you tube video I made. There are 4 parts. https://www.youtube.com/watch?v=4yhbhHZHrz8 |
04-21-2016, 07:10 AM | #2 |
Re: Starter drive bolts.
Well done!
04-21-2016, 09:29 AM | #3 |
Two diameters of Bendix bolts were used in the started drives, 5/16" in the Model A and 3/8" in the Model B, and perhaps later Model As. The 5/16" bolts have a relatively lower fatigue life. Change the Bendix to the one that uses 3/8" diameter Bendix bolts.
Bob Bidonde |
04-21-2016, 10:27 AM | #4 |
