07-29-2015, 09:28 PM | #1 |
Miss Fire!!
I have a B engine in my 30 speedster that was running like a top. Was in the 4th of July parade and ran out of water. Got hot and it stopped! Had to tow it home. The block was cracked, externally! With the help of J/B weld and block seal did the trick. As it was down I adjusted the valves. So far everything is going smooth RIGHT? WRONG!! It started right up. Running a little rough. Let idle a few minutes. Checked the wires to be sure they were on right, they were. #4 is missing. Checked the points, Put in new plugs change the wires, cap, rotor,check the comp. 65 lbs in all Cyl . #4 cyl. is dead What is wrong?? Any help Please!!!!!!
07-29-2015, 09:32 PM | #2 |
Re: Miss Fire!!
Are you sure when you adjusted the valves you didn't mess one up on No 4 so that it is now not closing?
B blocks are renowned for cracking. Once you get it going again, keep a close eye on the water for oil. If it cracked badly enough that it was visible on the outside, I suspect serious damage lurks within.
07-29-2015, 09:46 PM | #3 | |
Re: Miss Fire!!
07-29-2015, 10:13 PM | #4 |
Re: Miss Fire!!
No bubbles showing up in the rad coolant? How's the number 4 plug look like after running the engine? Is it just flooded with gas or is it wet with coolant also?
07-30-2015, 05:17 AM | #5 |
Re: Miss Fire!!
Make sure your getting good spark to that cylinder.
Spray around the intake gasket to see if you have a vacuum leak Do a leak down test on #4 cyl |
07-30-2015, 05:36 AM | #6 |
Re: Miss Fire!!
07-30-2015, 08:30 AM | #7 |
Re: Miss Fire!!
I doubt weak valve springs are going to cause a low engine speed mis-fire.
If all holes have good compression then that cylinder seems to be in good condition. As mentioned, I too would recommend making sure there is good fire and no vacuum leak. I wouldn't assume anything. I read the OP has having good compression on all holes. Last edited by Patrick L.; 07-30-2015 at 10:13 AM. |
07-30-2015, 08:38 AM | #8 |
Re: Miss Fire!!
Dead how? No spark at all?
07-30-2015, 08:55 AM | #9 |
Re: Miss Fire!!
Compression tells a story. Cylinder No. 4 has none. Points to consider:
> As No. 3 has good compression, the head gasket does not have the classic burnout between Nos. 3 & 4; > You adjusted the valves, but made no comment about the valves in No. 4, so I am guessing you were able to successfully adjust the clearances. So the loss of compression may be due to one or both the valves leaking at their seats. A crack into either of the valve seats and or burned valves may be the culprits; > Another possibility is a crack in the block allowing compression gas to leak past the rings, or escape into the cooling system. Bubbles seen in the coolant at the top tank of radiator are not a good indicator of compression leakage into the cooling system of a Model A Ford. My recommendation is to remove the cylinder head and do a thorough inspection of the combustion chamber of No. 4.
Bob Bidonde |
07-30-2015, 08:58 AM | #10 |
Re: Miss Fire!!
says #65 lbs in all cylinders.... i am thinking number 4 also.... states #4 is dead i am thinking dead in not firing
07-30-2015, 09:51 AM | #11 |
Re: Miss Fire!!
I've seen a couple distributor bodies have crossfire between 3 and 4 and cause a miss. Try the easy things first, like another distributor body. An engine scope would show what's up with plugs firing.
If you have a slow to close valve, then you can have good compression at cranking speed, but not at running speed. Connect a vacuum gauge and see if it remains steady during the miss. |
07-30-2015, 10:34 AM | #12 |
Re: Miss Fire!!
Not to overstate the obvious, but this is a reminder that our A's are not like our modern cars, which are almost maintenance-free. We should adopt habits of checking oil, water, and tires (at least) every time before we take the car out.
07-30-2015, 11:22 AM | #13 |
Re: Miss Fire!!
my thoughts would go to the point's cam in the distributor and on number 4 the points may not be opening the same as the rest of the cyl.
just a guess because it sounds like you covered all other possible's good luck terry |
07-30-2015, 11:40 AM | #14 |
Re: Miss Fire!!
First you need to see if you have a nice blue spark to that cylinder. If you do I would say you cracked the block on number 4 by the valves. Number 4 gets hotter than 1,2. If it is cracked you will get water on the plug which will stop it from firing. Because you said it ran ok until it got hot, it most likely has some thing to do with getting real hot. It won't be the valve springs.
07-30-2015, 01:16 PM | #15 | |
Re: Miss Fire!!
#4 has 65 lbs. just like the rest of them. No water on the plug. I have taken the plug out and ran the engine and the plug fires there is good spark put the plug back in and that cyl. does not fire!! With the motor running, I stuck the comp. gage into the hole and have good compression. It is running on 3 cyl.!!!! Am at witts end!!!!! Any other ideas========= PLEASE!!!! # |
07-30-2015, 01:22 PM | #16 |
Re: Miss Fire!!
did you ck for a vacuum leak and then do a leak down test? as mentioned in post #5
07-30-2015, 01:23 PM | #17 |
Re: Miss Fire!!
Try a different spark plug.
07-30-2015, 01:23 PM | #18 |
Re: Miss Fire!!
Switch that plug around and see if it changes the miss. I'll bet that plug has a cracked insulator that is not visible. The Cap may have internal carbon tracking grounding out #4 post.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
07-30-2015, 01:27 PM | #19 |
Re: Miss Fire!!
in the original post he switched the plugs did a full tune -up
but he can try switching the new plugs from cyl to cyl for shits and giggles you never know maybe a new one is bad |
07-30-2015, 01:36 PM | #20 | |
Re: Miss Fire!!
Thread Tools | |
Display Modes | |
