02-08-2017, 06:12 PM | #21 | |
Re: Rim Liners?
It's a solid cardboard, like a thick cereal box. |
02-08-2017, 08:06 PM | #22 |
Re: Rim Liners?
Note to self. Save those cereal boxes.
All steel from pedal to wheel |
02-08-2017, 08:14 PM | #23 |
Re: Rim Liners?
Duct tape is ok but last Labor Day (emergency) I used an old
bicycle tube. Next flat I`ll get the size. |
02-09-2017, 11:28 AM | #24 |
Re: Rim Liners?
I've had the rim liners in the tires for over 40 years,no flats as of yet,knock on wood.
02-09-2017, 12:20 PM | #25 |
Re: Rim Liners?
Yes, some type of liners are good to use. If you have rusty rims(like I had on my old rig) the rust will mess up your tubes over the years.
02-09-2017, 12:36 PM | #26 |
Re: Rim Liners?
02-09-2017, 12:49 PM | #27 |
Re: Rim Liners?
If you have your tires and tubes off the rims already ---- YES install the liner. First sand down the inside of your rims anyways to create as smooth a surface as you can. Light coat of primer, light coat of rustoleum allow to dry then install your rubber liner and proceed to install the tire and tube.
I did mine in 2001 and have not had any issues with flats! Check your tire pressure along with all other routine maintenance and you will not have any issues!
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
02-09-2017, 03:26 PM | #28 |
Re: Rim Liners?
The flap that is mentioned is probably what we (Michigan) called a boot. like someone above mentioned they were used to get more miles out of a otherwise bad tire. Some were so large that you could feel the thump as you went down the road.
02-09-2017, 03:51 PM | #29 |
Re: Rim Liners?
From Coker's web site;
Flaps ......................................... Rim Strip
02-09-2017, 05:07 PM | #30 |
Re: Rim Liners?
A flap is not a boot and maybe not the best for a drop center rim I guess.
02-09-2017, 05:27 PM | #31 |
Re: Rim Liners?
Would u put on pants without underwear
02-09-2017, 05:49 PM | #32 |
Re: Rim Liners?
Not sure what the term is over there but that is called "Going commando" here. Only happens when the husband arrives home early.
02-09-2017, 08:44 PM | #33 |
Re: Rim Liners?
02-10-2017, 07:17 AM | #34 |
Re: Rim Liners?
02-10-2017, 10:40 PM | #35 | |
Re: Rim Liners?
Personally, I like Gorilla Tape. It is like duct tape, but much more durable.
Style beats speed any day, and with a lot fewer tickets. |
02-11-2017, 04:43 AM | #36 |
Re: Rim Liners?
02-11-2017, 04:53 AM | #37 |
Re: Rim Liners?
But if there were only one gaffer, gaffer's tape.
02-11-2017, 08:24 AM | #38 | |
Re: Rim Liners?
Would you believe me if I said that was the American spelling? My wife found that excuse worked for almost anything when she studied in Oxford. Actually, I debated where to put the apostrophe, so I actually took a moment to look up how the sellers spelled it. I found three variations: Gaffer's Tape; Gaffers' Tape; and Gaffer Tape. The most common I found was Gaffer's Tape. Ken (the chagrined)
