03-11-2023, 03:40 PM | #1 |
Headlight bulb replacement
So here is my first question as a new 36 Model 68 sedan convertible owner and it’s a dumb one.
I am trying to replace the headlight bulb and I can’t figure out how to get the old bulb out. I’ve never seen a setup like this. I’m afraid to twist or pry on anything too hard for fear of breaking the bulb or damaging something. Can someone give me step by step instructions? Probably really easy Thanks in advance |
03-11-2023, 04:05 PM | #2 |
Re: Headlight bulb replacement
it twists, the 3 little nubs have springs behind the reflector, it could be so used to being in the same position that it is stuck
03-11-2023, 07:01 PM | #3 |
Further to what kurt has posted, try spraying your favourite penetrating oil around the flange; it will certainly help. And, you twist to the left to remove....
03-11-2023, 07:29 PM | #4 |
First push in and then twist. You can twist all day long and never the remove the bulb unless you first push the bulb in.
03-11-2023, 08:41 PM | #5 |
I suggest wearing leather work gloves to protect your hands when you are pushing and twisting on the bulb.
03-11-2023, 09:22 PM | #6 |
03-11-2023, 10:05 PM | #7 |
If you use penetrating oil I suggest you be very careful cleaning it up. The silver plate on the reflectors is very thin, you can wreck it easily. Soft cotton cloth, silver polish, google for instructions, really, its thin and if you have nice reflectors you are lucky!
03-12-2023, 07:14 AM | #8 |
The “per-focus” bulbs with the 3 hole flange do not push in any, they just turn, but you might have to push on the spring loaded pins some from the backside.
While a slight amount of oil will help it has to be removed to prevent the heat of operation from vaporizing any of the oil and depositing a cloudy film on the lens and reflector. |
03-12-2023, 09:55 AM | #9 |
I somehow think David G said it right, push gently in and turn left. WD 40 might help loosen without damage.
03-12-2023, 11:55 AM | #10 |
Here is a pic of the head light socket and 2 pics of the bulb.No springs.Springs are in the socket itself around each connector terminal.
03-12-2023, 01:04 PM | #11 |
Sheldon,
You're right; I must have been thinking of the '32-'34 versions. |
03-13-2023, 09:29 AM | #12 |
If you don't have a replacemrnt bulb already, i suggest the bright bulbs from
03-13-2023, 09:33 AM | #13 |
If you don't have a replacement bulb yet, I suggest the bright bulbs from Ron Francis Wiring. It is a brighter bulb than the originals and they have them for 6 or 12 volts. They are much brighter. terry
