04-16-2012, 09:39 PM | #1 |
correct wiring harness for 1936 Ford
Can anyone tell me if the wiring harness for Mac's Cowl Dash wiring harness (68-14401) contains the generator cutout wire and coil to resistor wire? Or is there a different harness that I should be ordering? I am wanting to get the wires that i need to pull thru the spark plug tube on the left side of the engine.
Thanks |
04-16-2012, 09:49 PM | #2 |
Re: correct wiring harness for 1936 Ford
Well the wire from the coil to ignition block and gen connects are separate you can make them up yourself. Certain yrs are not available from the catalog.
04-17-2012, 03:11 AM | #3 |
Tom |
