04-16-2012, 04:51 PM | #1 |
motor temp. 2
i found an old junk yard local, well 25 miles in the sticks. got a '38 truck fan. 6 blade 2" hub 15 3/4 blades. took off the electric fan, the 6 volt alt. and installed the original gen. and fan fit beatiful. i think i should have the temp. problem under control. I HOPE!!!!!! i won't know till tomarow.
04-16-2012, 05:15 PM | #2 |
Re: motor temp. 2
I did the same thing to my 46 Ford. I pulled the 4 blade and installed a 6 blade and had Skip rebuild my water pumps. My car runs about 150-160 now in 70-80 degree temps. I haven't had any problems with the gas boiling in the carb yet. I'm hoping my problem is salved also. Good Luck with your project.
04-16-2012, 05:26 PM | #3 |
Re: motor temp. 2
I don't like to run my engine under 180 deg.
04-16-2012, 05:38 PM | #4 |
Re: motor temp. 2
Flatjack, i got 180 stats.
04-16-2012, 07:11 PM | #5 |
Re: motor temp. 2
Good choice.
04-16-2012, 11:03 PM | #6 |
Re: motor temp. 2
www.fordcollector.com |
04-17-2012, 10:11 AM | #7 |
Re: motor temp. 2
I just installed SW Gauges electric temp,When running along 55 mph its says 190Degs.When idling goes up to 210.When first starting engine last year had a mech gauge and didn,t have enought water and cooked the gauge.I did have over heating problem and put new Walker Raditor,then pumps were leaking put new ones. The engine is 255 with .060 over with sleeves,and 180 temps.This is first time with gauge and not over heating.I also put gauge on pass side thats the hot side.New gas gauge
didn,t would to run out.Set float up little.Turned key and had 1/4 tank,filled and took 11 gallons.So empty should still have few gallons. |
