04-15-2012, 03:51 PM | #1 |
Coolant overflow
This is not making any sense. My '50 Ford with the V8 is acting rather strange. A couple weeks ago I changed the coolant after removing the heater and bypass hoses. Now it seems to blow out coolant out the overflow whenever it chooses. By this I mean today I drove all over town stopping and going running errands, and when I got finished and parked her in the garage the coolant level was fine. Well after lunch we decided to take a drive, a 60 mile round trip out to the country running about 55 - 60 mph. When we returned about a pint of coolant had gone into the overflow. The car runs perfect, no over heating, no smoke, has the correct radiator cap that's about a year old. I made sure that there is no air pockets after the fluid change, and I can see the coolant flowing pertectly as it is running. I have the coolant level just above the coils in the radiator. I did a compression test yesterday, and except for #5 at 70 pounds the rest around 90# the same as it tested a couple years ago. Prestone antifreeze with 50/50 mix is what I always use for coolant - so what are your thoughts - just live with it or ???
04-15-2012, 04:48 PM | #2 |
Re: Coolant overflow
It is either the pressure cap is not working or not seating down at the seat about 1" down in the neck. If they are OK it's a slight compression leak which Barrs heavy duty stop leak should take care of. A bad compression leak push larger amounts of water out. G.M.
www.fordcollector.com |
04-16-2012, 02:08 PM | #3 |
I just bought a new cap and some Barrs - wish me luck.
04-16-2012, 04:04 PM | #4 |
