05-19-2019, 02:53 PM | #1 |
why did my helmet distributor housing just crack? new rotor .
so I bought a new rotor for my helmet style distributor a few days ago and just changed it out. I put the distributor back on the 59ab 39 merc and when I cranking over the engine I noticed the distributor was wobbling around. I'm positive the key was matched up with the slot in the cam . what did I do wrong?
05-19-2019, 02:56 PM | #2 |
Re: why did my helmet distributor housing just crack? new rotor .
Sure sounds like it wasn't seated when the bolts were tightened down.
05-19-2019, 02:57 PM | #3 |
The slot in the cam is slightly offset from center as is the tab on the distributor. It is possible to put it together with the slot and the tab 180 degrees off. Have you checked that yet?
05-19-2019, 03:05 PM | #4 |
thats probably it. I guess it's a costly lesson learned .
05-19-2019, 03:14 PM | #5 |
Sad, but most likely true.
05-19-2019, 05:25 PM | #6 |
05-20-2019, 12:36 AM | #7 |
C&G is just down the road in Escondido. You can't get better than that.
C&G Ford Parts www.cgfordparts.com Ford and Mercury cars from 1932 to 1972, Pickup Trucks from 1932 to 1979
Alan |
05-20-2019, 12:45 AM | #8 |
Installation error i'm guessing.
Send it off to bubba. He did two for me. One for now and one for whatever (always order two). Think charlieny,skip does them to. |
05-20-2019, 05:08 AM | #9 |
What style helmet ? 33-36 or 37-41? Try The Early Ford Store,San Dimas or V8 Garage in W Covina,Kennedy Brothers in Pomona.Lots of cores out there.
05-20-2019, 10:21 AM | #10 |
Then - when you tighten the bolts, puts a heck of a strain on the case (as I believe the slot is about 1/16 offset). The whole reason Ford put the offset in the slot was to ensure that the firing order was correct when you took a distributor on/off the vehicle.
05-20-2019, 10:33 AM | #11 |
I have found that nothing makes the job of installing the distributor as easy as using two studs to align the gasket and distributor. Turn the rotor and and when the tang aligns the distributor will slid back tight to the block, put in the third bolt to hold it in place remove the studs install the other two bolts and you are finished.
05-20-2019, 01:08 PM | #12 |
Dont feel bad , i get them every week that are broken..........if ya cant find one out there we have a few boxes of them .................
05-20-2019, 04:44 PM | #13 |
I have an extra one boxed up that will be heading "Gas Mans" way tomorrow morning.
05-26-2019, 07:19 AM | #14 |
Hope it's okay with Gas Man to share this update. He got the distributor housing I sent him and after transferring parts from his cracked one, installed on engine and it fired right up. If the earlier problem occurred because of installation you can bet that mistake won't happen again. Really like the idea of having some studs to help line things up and plan on doing that in future to prevent problems.
05-26-2019, 11:50 AM | #15 |
Yes, good idea on the studs. I’ve always used studs for exhaust manifolds, clutches,etc. in big trucks. Never though about using them for a flathead dist.
Thanks for the tip! |
05-26-2019, 01:54 PM | #16 |
GaryU, You did a very nice thing to help with the distributor, and it's back on a car and helping gas man! Good on you!
05-26-2019, 04:06 PM | #17 |
If it might help anyone at all, I demo how a distributor ought to fit to the motor in one of my videos.
https://youtu.be/6UsbbUdAtCw If you watch from about the 2 minute mark to just after the 4 minute mark, you can see me offering up and fitting the crab distributor on my 41 pickup. A helmet type will offer up and clunk into place in the same way. If there is any resistance, something is probably wrong. Mart. |
05-27-2019, 04:30 PM | #18 |
Be sure you had the correct rotor. Also, it may have been one of the current offshore parts that we see today. It only takes one revolution of the distributor with the wrong rotor or defective to break it.
05-27-2019, 06:10 PM | #19 | |
05-27-2019, 10:01 PM | #20 | |
Yep a rotor that hasn't been filed to fit would easily crack a cap. Best to know what condition your condition is in . Maybe a picture of said Dizzy. A 59a wasn't a helmet. Not saying that's not what is there. Just for clarification. Think in 39 it was a 81a or a 99 block. Not sure. See Gary straighten you out. Just curious on details. . . Last edited by Tinker; 05-27-2019 at 11:15 PM. |
