12-25-2015, 11:51 PM | #21 |
Re: 1 wire vs 3 wire alternator
With the success and satisfaction so hit or miss on the one wire Delco for decades, I don;t know why anyone wouldn't keep their Ford all Ford with the far superior 3G charging system.
12-25-2015, 11:52 PM | #22 |
The standard 3-wire GM SI-series or clones can be run as 1-wire, 2-wire or 3-wire setups.
For a 1-wire, run a pigtail wire from the #2 sensor terminal directly to the battery output terminal. The #1 exciter terminal is left open. Without the exciter terminal connected, you sometimes must rev the engine a bit to get it to start charging from residual magnetism in the alternator. For a 2-wire setup, again run a pigtail from #2 to the battery output terminal. The #1 terminal is then connected to the ignition switch thru a ~1 amp bulb and/or 10-ohm resistor. Run-on shouldn't be an issue with the bulb or resistor. For a 3-wire setup, run a wire from #2 to some remote circuit location to sense voltage at that point. The #1 terminal is connected like the 2-wire setup. The 3-wire is probably the best setup to keep battery properly charged. Jack E/NJ |
12-25-2015, 11:57 PM | #23 |
Anyone use this guy??http://www.gener-nator.com/index.htm
12-26-2015, 09:27 AM | #24 | |
Whitney Co., Inc., E. J. 529 S. Raymond Ave., Fullerton, Ca 714-773-1611 |
12-26-2015, 09:30 AM | #25 | |
12-26-2015, 09:31 AM | #26 |
Its an alternator or parts made to fit the case whatever he says..lol |
12-26-2015, 05:31 PM | #27 |
Hi there, All the above discussion is about TWELVE VOLT alternators. Any one who knows for a fact (NOT JUST GUESSING) information on 6 volt Delco 10si alternators. From my experience there is only a single wire unit available (not 2 or 3 wire) which is governed by the design of the 6 volt inbuilt regulator which will work for both Negative & Positive ground. The inbuilt diode pack has to be a Negative or Positive ground unit to suit the vehicle battery polarity ground connection. The alternator stator winding and rotor are the same for both 6 & 12 volt applications. These 6 volt alternators require a small pulley and some engine revs to start them charging. Will a 24 volt rated stator winding improve this situation in a 6 VOLT alternator. Factual comments please and not just guesses. Thanks, regards, Kevin.
12-26-2015, 06:11 PM | #28 |
You should have the 2 terminals available on the side of alternator.
One of them should be able to excite the unit. That should be the Nr 1. terminal. On a positive unit that means closing a circuit between case and nr 1 terminal. NOT BATTERY POST !!!!! Last edited by flatheadmurre; 12-26-2015 at 06:21 PM. |
12-26-2015, 06:31 PM | #29 |
Self excite will gain from having a higher voltage stator since it takes less residual magnetism to produce a certain voltage to wake the unit up.
If its been sitting to long and lost most magnetism you still need to excite it by hooking up current to it. Low rev charging gains from more poles on the rotor. |
12-26-2015, 06:37 PM | #30 |
12-26-2015, 06:45 PM | #31 | |
