04-17-2012, 01:06 PM | #1 |
'36 Helical First Gear In Later Trans?
I have picked up a few new 68-7100B first gears and want to use them where 01A-7100 first gears are otherwise correct. Will the first-rev shift fork have a problem with the earlier helical gear? Are the top shift first-rev forks the same back to the B-7231? Looking for ways to freshen up trans with worn gears. Thanks: Fred A
04-17-2012, 04:35 PM | #2 |
Re: '36 Helical First Gear In Later Trans?
Aside from all that, the tooth count, tooth shape, and the spiral splines are identical between the two gears.
VANPELT SALES LLC Cincinnati, Ohio Office: 513-724-9486 www.vanpeltsales.com www.classictransmission.com |
