Old 04-14-2012, 08:59 PM   #1
John Kennedy
John Kennedy's Avatar
Default Need 29 Sedan measurements please
Hey guys, I'm hoping someone out here has body dimensions for my 29 Tudor Sedan. Body is all stock, no wood involved.
I'm particularly interested in left-right measurements above the roof edges and getting my door alignments right. My right side front-roof area is splayed out some, windshield area seems fine.
Any suggestions? Thanks!
John
Building a 29 Sedan on 32 chassis........ very slowly....
John Kennedy is offline   Reply With Quote
Old 04-15-2012, 08:52 PM   #2
John Kennedy
Default Re: Need 29 Sedan measurements please
Anybody? I assume the front upper roof edges are parallel ahead of the doors? Or do they taper inwards some?
Old 04-15-2012, 09:04 PM   #3
4dFord/SC
4dFord/SC's Avatar
You might have better luck on the Model A Forum.
4dFord/SC is offline   Reply With Quote
Old 04-15-2012, 09:11 PM   #4
T&A Flathead
I have a 29 tudor that i can measure, but i don't really understand what you need.
T&A Flathead is offline   Reply With Quote
Old 04-16-2012, 01:33 AM   #5
Tudortomnz
Tudortomnz's Avatar
I also have one that I will measure if you explain exactly what you require.
Tudortomnz is offline   Reply With Quote
Old 04-16-2012, 08:04 AM   #6
John Kennedy
I just want to verify that the front roof pieces remain parallel along the roof edge, as opposed to tapering inwards. Is it a straight shot from the doors forward?
Old 04-16-2012, 09:04 AM   #7
merc40
on my 31 2 dr. they taper down to where meet the top of the door. reguards dick t.
merc40 is offline   Reply With Quote
Old 04-16-2012, 07:31 PM   #8
John Kennedy
OK, that's what I did too. Everything else seems right on so far! Now I just gotta get past my surgery and get back on things!
Old 04-17-2012, 01:46 AM   #9
Tudortomnz
Tudortomnz's Avatar
The outer edge tapers towards the front pillar, exactly as the top edge of the door does.
Old 04-17-2012, 03:12 AM   #10
Mart
Mart's Avatar
If you think the one side looks all right, you can string a center line down the center and make the bad side match the good side.
Mart.
