06-16-2012, 02:15 PM | #21 |
Re: Anyone tried the Lucas-recommended mix of 80W-90 and Heavy Duty Oil Stabilizer?
I promised to report back on putting the Lucas mix into my transmission and the report is that it made no difference at all in the grinding of the gears. They still grind just great!
06-16-2012, 02:26 PM | #22 | |
I know that I have picked up great tips from the "off topic" postings.
06-16-2012, 03:04 PM | #23 |
We've been discussing this for a while now. I too have been experimenting. Since the Lucas rep recommended against straight Hub Oil in the trans and diff. I mixed up 50/50 hub oil and 600w from Snyders. Only been a few miles, but it's not as quiet as with straight Hub Oil. Still, quieting the gears isn't the only factor we're looking for. We've mentioned preventing foaming, slowing leaks, and, of course, we'd have to run each mixture for many miles to see if there are differences in wear on gears.
I'll stick with the 509/50 mix I've got now for a year and see what happens.
Forty horses is plenty. |
06-16-2012, 04:33 PM | #24 |
I'm restoring a 1930 fordor and am about three months away from being able to drive it. I've restored the trans and differential, and am considering using Lucas Oil Stabilizer mixed (50:50?) with Lucas 90-140 gear oil (rather than Lucas 40-90 oil) for both the trans and rear end.
Has anyone tried this combination? I recall that the late Roger Kaufman used to advise in his tech column in MARC's magazine that he used 100% STP in his trans, had been doing it for several years, and was extremely satisfied with the result. Don't recall if he used STP in his differential. |
06-16-2012, 05:20 PM | #25 |
I just put 100% LUCAS heavy oil stablizer in my Tudor's transmission, only had time to drive it 4 miles between thunderstorms. Seemed very good. Will see how it works after a much longer drive.
Jon "If you choose to not decide, you still have made a choice!" RUSH Don't tell me what you know..... Tell me what you have done. |
06-16-2012, 06:50 PM | #26 | |
[From his tech. column] |
06-21-2012, 11:38 AM | #27 | |
Thanks! Mike Green |
06-25-2012, 10:49 AM | #28 |
Well, I drained my tranny and differential and replaced the old 600W with 100% Lucas heavy oil stabilizer.
Results? No difference at all from 600W. Maybe it will not leak as much though! Next time straight 600W for me. |
06-25-2012, 12:29 PM | #29 |
I'm running Mobilgear 600 XP 680 with about 1 pint Lucas oil stabilizer mixed in. I just recently added the Lucas to the gear oil and noticed a slight improvement. Personally I can't imagine any better shifting in a straight cut, un-syncronized transmission.
I asked this question in another thread and got no response so I'll ask it here: Can anyone give a good reason why such a heavy oil is being used in the differential? |
06-25-2012, 03:28 PM | #30 | |
In a synchromesh transmisson it wouldn't be necessary. These are straight cut, non synchro gearboxes and the heavy oil slows the gears down while you shift. Oils as light as ATF have been used in modern, synchromesh, helically cut gear, transmissions with no problems. This helps gas mileage immensely, but it would probably be very difficult to shift.
Terry Quote:
06-25-2012, 03:51 PM | #31 |
I put the Lucas 80-90w and oil stabilizer mixed 1:1 in the transmission, drove 1300 miles and can't see any difference in shifting from the 600w oil from Snyders. JB
06-25-2012, 06:01 PM | #32 | |
06-25-2012, 09:48 PM | #33 |
I find that if you master the art of double clutching,there will be no gear grinding wether you use the 600w from the vendors or a 140 gear oil. 90 gear oil is fine for rear ends.Years ago when I used A,s as daily drivers,I would use140 in the trans for summer & 90 in the winter.If you tried to use 600 W in-30* temps,you would stall the engine when you let out the clutch.
06-25-2012, 11:43 PM | #34 | |
Yeah, I realized that, was going to change it and the phone rang then I went to eat to eat. The answer is (AFAIK)to keep the oil away from the brakes ????
Terry Quote:
06-26-2012, 07:33 AM | #35 |
I reduced all my gear grinding with a Mitchell syncro transmission. Hope this helps.
06-26-2012, 08:52 AM | #36 |
If you shift up at low RPMs and double clutch when downshifting, you can eliminate grinding. Read the original owner's manual! I use hub oil and the trans is as smooth as glass. The hub oil did fade somewhat after about 200 miles but still, whenthe gears slide in, the "click" is not at all harsh like it was. MUCH better than the 600W I bought from Mac's. Night and day difference really. When I change it out next year I will use the stabilizer.
06-26-2012, 08:59 AM | #37 | |
A sales person from Lucas recommended against using only a product from another manufacture? I find that hard to believe.... |
06-26-2012, 12:38 PM | #38 | |
Fred Kroon 1929 Std Coupe 1929 Huckster |
06-26-2012, 02:55 PM | #39 |
My Lord, I can't believe all this gobbeldy gook I've just read! We're not going to "re-engineer" the shifting characteristics of a Model A by some witch's brews! The secret to shifting is just to be patient & wait. Why waste gas & power just churning around un-needed GOO!
Some "brews" remind me of a bartender trying to cover up the awful taste of some of his "HOOCH!" Bill W.
06-26-2012, 03:01 PM | #40 | |
