Old 05-19-2019, 12:49 PM   #1
jm29henry
jm29henry's Avatar
Default Water outlets
When using the copper inlet and outlet gaskets do you need to use any sealant or permatex with the gaskets
jm29henry is offline   Reply With Quote
Old 05-19-2019, 12:57 PM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Water outlets
I usually don't use gasket sealer but sealer wouldn't hurt as long as it is used sparingly .
Old 05-19-2019, 03:39 PM   #3
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
I use just sealer, no gasket and torque only to 45 ft. #.
Jacksonlll is offline   Reply With Quote
Old 05-19-2019, 08:24 PM   #4
jm29henry
jm29henry's Avatar
Going for touring class judo in August I hope the motor looks the best it possible can thank you so much purity and Jackson
Old 05-19-2019, 09:28 PM   #5
1crosscut
1crosscut's Avatar
I like to use a thin coat of Indian Head shellac.
Dave / Lincoln Nebraska
1crosscut is online now   Reply With Quote
Old 05-20-2019, 08:20 PM   #6
jm29henry
jm29henry's Avatar
Thankyou 1crosscut
