Old 03-25-2024, 04:28 PM   #1
Kube
Kube's Avatar
Default wheel / hub cap fitment issue
Hello guys,
My guess is I have either the wrong wheels or the wrong hub caps...
1931. The ID of the wheel where the cap will be placed is 3 3/4".
The OD of the hubcaps I have is 4 1/8". The distance from one bent tab to the one opposite is 3 1/4".
Kind of a BB in a boxcar.
So, what say you?
Thanks.
Old 03-25-2024, 06:08 PM   #2
180 a
Default Re: wheel / hub cap fitment issue
I think the larger hub caps fit the early V8
180 a is offline   Reply With Quote
Old 03-25-2024, 06:27 PM   #3
Bob C
Can you post some pictures?
Old 03-26-2024, 05:56 AM   #4
nkaminar
nkaminar's Avatar
Wrong hub caps.
Old 03-26-2024, 08:22 AM   #5
Kube
Kube's Avatar
Originally Posted by nkaminar View Post
Wrong hub caps.
So, you believe the hole in the rim is the correct diameter?
Old 03-26-2024, 10:46 AM   #6
nkaminar
nkaminar's Avatar
Photos would help. The Model A hub cap can be hard to put on and require the tabs to be bent in a little. That may be the problem.
Old 03-26-2024, 11:06 AM   #7
katy
katy's Avatar
What size are the rims? 21"? 19"? 18"? 17" 16"? Or?
