Old 03-11-2021, 07:43 PM   #21
Will D
Will D's Avatar
Default Re: Engine install
failure? No, just a work in progress.
Sometimes, ingenuity gets in the way of sense and sanity.
Will D is offline   Reply With Quote
Old 03-12-2021, 04:44 AM   #22
flatford8
flatford8's Avatar
I’d definitely loosen the trans mounts to give some wiggle room.......it’s good your feeling better.......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 03-12-2021, 05:45 AM   #23
Mart
Mart's Avatar
It needs to be perfectly aligned to go together, both angularly, and up and down and side to side. Don't forget the shaft must be rotated to get the splines in angular alignment.
When putting the motor in my 33 I had the inspection cover off and was able to put a long pointed bar through the hole and push the splines around until they finally aligned and slipped in. Shine a good light down there so You can really see what is going on.
Mart.
Old 03-12-2021, 08:40 AM   #24
AnthonyG
AnthonyG's Avatar
Good Tip removing window plate on Trans !
Thx Mart!
Nomad
AnthonyG is offline   Reply With Quote
Old 03-12-2021, 08:41 AM   #25
AnthonyG
AnthonyG's Avatar
Thx Mark!
Nomad
Old 03-12-2021, 09:53 AM   #26
AnthonyG
AnthonyG's Avatar
I’m Probly getting paranoid now but after Marts look in tranny window idea, the spline doesn’t seem to get past the bevel on the front of the thrust Spline. Can Someone confirm dimension on ‘39 tranny to clutch spline major diam is 1.375 minus a couple? I should of compared My actual tranny spline dimension w the busted one I used as the alignment tool but didn’t and don’t wanna pull engine to check
Nomad
Old 03-12-2021, 10:25 AM   #27
Mart
Mart's Avatar
Yeah it's 1-3/8" 10 spline.
Mart.
Old 03-12-2021, 02:09 PM   #28
AnthonyG
AnthonyG's Avatar
Loosened tranny mounts & must have given enough extra play & spline finally meshed! Also opening window on back of tranny helped big time as I could see the spline when aligned, Thx Mart! Whew, made me work !
Nomad
Old 03-12-2021, 02:57 PM   #29
Mart
Mart's Avatar
Well done, Anthony. Good job.
Old 03-12-2021, 03:07 PM   #30
Will D
Will D's Avatar
Ditto. Always nice to see a thread with a resolution.
Old 03-12-2021, 03:33 PM   #31
19Fordy
19Fordy's Avatar
That's great news Anthony. Do a little write up and post it on Fordbarn for folks who may need the info. When situations like that occur, I always say, "Wait a minute, I can't be the only person ever confronted with this problem. Therefore, it's solvable."
Old 03-12-2021, 04:48 PM   #32
AnthonyG
AnthonyG's Avatar
Thx Guys for the good words, encouragement & help. Will do a little write up for anyone who might go thru it as you say 19Forty & I’ll give Mart credit for great idea removing the “take a peek” window cover on the back of the Trans, little thing but Giant help!
Nomad
