Old 02-28-2021, 06:30 PM   #1
coatings03
Default Battery warmer
hellow fellow barners, i had an experience with cold weather approx 42 degrees with my 29 speedster. I had it covered as we had a cold spell in southen Calif.
my 6 volt battery was dead after 2 days. I charged it up and it was fine. I have seen these battery warmer that are pluged in keeping the battery at 70 degrees.
any experience with these units?
thanks,
jim m
coatings03 is offline   Reply With Quote
Old 02-28-2021, 07:55 PM   #2
Doug Linden
Doug Linden's Avatar
Default Re: Battery warmer
Well 42 degrees in my area would be considered a mild day. I think there is something more that the "cold" weather causing your battery to go dead in two days. Here we can leave the battery sit for a month or more and the Model A will still start up.
I would recommend using a good quality battery maintainer to keep the battery fully charged when not in use in any weather.
Doug Linden is offline   Reply With Quote
Old 02-28-2021, 11:50 PM   #3
CWPASADENA
CWPASADENA's Avatar
42 degrees is not considered really cold. I think you have other issues, either something draining the battery or a bad battery.
I drove a Model A to collage in Missouri and it always sat outside. 6 Volt and it always started. When it got down close to zero, I would put a drop light under the hood and put a blanket over the hood. That little bit of heat would help with it cranking in the morning. It would barely turn over but it always started.
If you are using an alternator, they can have a bad diode that will "leak" and cause the battery to run down. A diode "Cut Out" can also cause the same thing.
My Model A's will sit for weeks and start right up. All 6 volt and with generators and original cut outs. I have my '32 Roadster parked where it is hard to get to and it will start after sitting several months. again 6 volt and a generator, but I do use Optima Batteries in all my cars. I do not have any of them on battery tenders.
My opinion.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 03-01-2021, 01:42 AM   #4
mass A man
mass A man's Avatar
Jim, have you checked for a slight electrical battery drain going on in your speedster? 42 degrees is "balmy" for us. You may have one cell about to completely fail in that battery also. A hydrometer will detect it. I've had that happen with the "Exide" 6 volt batteries. They're real junk in my book.
mass A man is offline   Reply With Quote
Old 03-01-2021, 09:13 AM   #5
Big hammer
Sorry you where suffering at 42*F , your battery shouldn't go dead in two days, find the discharge or remove a battery cable ! Years ago I placed a trouble light by my battery because of temperatures below -0- and it started fine the first morning, the second morning the light bulb had burned out it started but was very slow.
get a bigger hammer tap done
Old 03-01-2021, 11:32 AM   #6
katy
katy's Avatar
Originally Posted by coatings03 View Post
I have seen these battery warmer that are pluged in keeping the battery at 70 degrees. any experience with these units?
thanks, jim m
Battery warmers help with marginal/weak batteries when it is 20 or 30 or more below zero.
Old 03-01-2021, 05:00 PM   #7
shew01
shew01's Avatar
It didn’t know such a thing exists. I never heard of it before.
Kat's 22200 80 Watt 36" Battery Thermal Wrap https://smile.amazon.com/dp/B000I8XD...9JBH5WG0WNFG5V
I’ve heard of block warmers before though.
shew01 is offline   Reply With Quote
Old 03-02-2021, 10:32 AM   #8
katy
katy's Avatar
Battery warmers have been around for 50 - 60 years, maybe longer.
Old 03-02-2021, 11:15 AM   #9
alexiskai
alexiskai's Avatar
I have one, it works as described. I don't use it for the battery. I keep it for other random cases where I need to keep something warm overnight, like I could drape it around the block as a makeshift block warmer, or I could wrap it around a bucket of rust remover to help the process along. It's a versatile tool.
Old 03-02-2021, 05:00 PM   #10
Ivan in southeast va.
Ivan in southeast va.'s Avatar
42 degrees, were the roads salted?
Ivan in southeast va. is offline   Reply With Quote
Old 03-03-2021, 08:56 AM   #11
Patrick L.
Patrick L.'s Avatar
I agree with the others.
You have a draw or bad battery. Maybe you have both. The draw shouldn't be hard to find and fix. Also make sure the battery connections are removed and cleaned, especially the ground at the frame.
Old 03-03-2021, 11:58 AM   #12
rocket1
42 deg. is not going to kill your battery,you might have a drain or need a new battery.My A sits in the garage through temps as low as 13 deg. and will start right up (groans a little)lol.
rocket1 is offline   Reply With Quote
Old 03-04-2021, 09:47 PM   #13
eagle
eagle's Avatar
The best "battery warmer" for when it gets cold out, here that is 20 degrees below zero or colder, is a trickle charger on the battery. It is really hard on a battery to start a car when its cold out. A trickle charger in cold weather will give you several years more of use out of a battery.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
