Old 03-01-2020, 07:50 AM   #1
Brian SATX
Brian SATX's Avatar
Default Distributor paint
The exterior of the distributor is semi-gloss black. Does the inside get painted or left natural?
Brian SATX
Brian SATX is offline   Reply With Quote
Old 03-01-2020, 08:11 AM   #2
wmws
Default Re: Distributor paint
Natural
wmws is offline   Reply With Quote
Old 03-01-2020, 08:30 AM   #3
leo
leo's Avatar
Don't over paint the distributor because it will play havoc with your ability to generate a proper spark at the points.
leo is offline   Reply With Quote
Old 03-01-2020, 08:49 AM   #4
30 Closed Cab PU
Bottom of the distributor that sits on the head, and the ignition cable threaded hole should be paint free/clean. They are major ground paths for the points. Also where the lower ignition plate screws to the distributor body.
Speaking from experience with a vendor rebuilt distributor.
30 Closed Cab PU is offline   Reply With Quote
Old 03-01-2020, 02:09 PM   #5
Tom Endy
Tom Endy's Avatar
I paint the inside of the distributor when restoring one to prevent it from rusting. However, when painting a distributor both the inside and the outside should be carefully masked to prevent painting surfaces that are important for grounding purposes. The attached article is how I go about it.
Tom Endy
Tom Endy is offline   Reply With Quote
