Old 02-07-2021, 08:12 PM   #1
JayJay
Default Zenith carb question
I believe the answer is "no" but I have no basis for having that belief. So:
Is there any reason that a top half from a Zenith 1 carb cannot be mated to the bottom half of a Zenith 2? Both are later construction (single venturi, cast-in-place seat for the GAV).
I have two and it turns out that one top is unusable (excessive corrosion at the float valve, won't seal) and the other bottom is also (can't get the secondary well out, rusted in place).
Thanks.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
Old 02-07-2021, 08:53 PM   #2
jm29henry
jm29henry's Avatar
Default Re: Zenith carb question
Go for it!
jm29henry is offline   Reply With Quote
Old 02-07-2021, 09:48 PM   #3
Gary WA
Gary WA's Avatar
yes they can
www.whidbeymodelaclub.com
Old 02-07-2021, 11:28 PM   #4
Tom Endy
Tom Endy's Avatar
Dash one and dash two housings are often found mated up. I suspect that back in the day when these carburetors were turned in for a core at places like Pep Boys they were disassembled and tossed in a pile and overhauled and reassembled with little regard to the dash number.
Tom Endy
Old 02-07-2021, 11:46 PM   #5
Gary WA
Gary WA's Avatar
Thanks.
JayJay
Heat outer case where the secondary well is and squelch in cold water it will come right out. I use oxygen/acet. propane torch not hot enough.
Old 02-08-2021, 10:47 AM   #6
JayJay
Thanks, Gary. I tried MAPP but unsuccessful, I'll get out the big boy.
And thanks to all for your counsel, the hybrid appears to mate up well. I'm pretty sure that the -2 was the original configuration but I have no background on the -1.
JayJay
JayJay
Old 02-08-2021, 10:50 AM   #7
Purdy Swoft
Purdy Swoft's Avatar
i do mine the same way and it has always worked well for me . A propane torch is a waste of time .
