Old 09-16-2018, 09:13 PM   #1
00fxd
Default Coolant
Hi all. I am going to drain my coolant [water] in my '28 for the winter. If I drain via the petcock on the lower hose steel tube will I safely drain all with no chance of leaving residual water to freeze? Thanks, Frank.
00fxd is offline   Reply With Quote
Old 09-16-2018, 09:23 PM   #2
eagle
eagle's Avatar
Default Re: Coolant
It'll drain the system just fine, just poke a straw/wire or something into the petcock hole after it stops draining to make sure it isn't plugged. I run antifreeze in mine so number one it keeps the corrosion down and number two, don't have to drain it in the fall.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 09-16-2018, 09:42 PM   #3
00fxd
Default Re: Coolant
Thanks Eagle. My system is a bit leaky so I have been running water and WP lube.
Old 09-16-2018, 10:11 PM   #4
eagle
eagle's Avatar
Default Re: Coolant
I've never tried it but Water Glass (Sodium Silicate) is supposed to seal up the system without causing reduced efficiency or plugging of already compromised 80+ year old system. Mine is nice and clean yet and cools great on 50/50 mix.
Old 09-17-2018, 08:13 AM   #5
00fxd
Default Re: Coolant
I will look for some :-)
Old 09-17-2018, 11:56 AM   #6
djlanier
Default Re: Coolant
What antifreeze do you use, Eagle, in your 50/50 mix?
djlanier is offline   Reply With Quote
Old 09-17-2018, 07:18 PM   #7
eagle
eagle's Avatar
Default Re: Coolant
I get it from Napa. The parts guy at our local store is an old car guru and he told me which brand/type to use. Didn't even look at what kind it is as I've known him my whole life and trust he knows what he's talking about. So basically, I have no idea!
Old 09-17-2018, 08:14 PM   #8
30 Closed Cab PU
Default Re: Coolant
Previously on the Barn Thought I read to stay away from Antifreeze with silicates, stay with the Green antifreeze.
Is the additive above safe, it has Silicate?
30 Closed Cab PU is offline   Reply With Quote
Old 09-17-2018, 08:20 PM   #9
30 Closed Cab PU
Default Re: Coolant
[QUOTE=00fxd;1675754]Hi all. I am going to drain my coolant [water] in my '28 for the winter. If I drain via the petcock on the lower hose steel tube will I safely drain all with no chance of leaving residual water to freeze? Thanks, Frank
Store/fill with 50/50 green antifreeze, drain and save it in the spring for multiple winter storages. Helps keep rust/corrosion from happening during the winter due to condensation and no worries about freezing.
Make sure to use the green antifreeze.
Old 09-17-2018, 08:49 PM   #10
00fxd
Default Re: Coolant
Lots of good ideas here .... thanks Fella's. Glad to know that there would not be any coolant hiding low in the block .....
