Old 02-19-2016, 08:12 PM   #1
Rbeck204
Default 1953 customline door locks
I need to change the door locks on my 53 two door. I see the clips on the inside edge of the doors but could not budge them. Is there a trick to removing the clips that hold the door locks in?
Rich
Rbeck204 is offline   Reply With Quote
Old 02-19-2016, 08:17 PM   #2
Blu Dice
Blu Dice's Avatar
Default Re: 1953 customline door locks
63 years old - may need a little convincing. They are spring type clips so press down on the sides and squirt some WD40 too.
4 doors are better than no doors!
Blu Dice is offline   Reply With Quote
Old 02-20-2016, 10:02 AM   #3
Johnnydidd
Johnnydidd's Avatar
I removed mine as Blue Dice suggested using WD40 spray well and grip the clips with Vise Grips, then move up and down and pull.
Johnnydidd is offline   Reply With Quote
