Old 11-27-2019, 01:44 PM   #1
guam2250
Default Model A Mallory distributor, model K, type 13
Hello. Have a Mallory distributor, model K type 13. It is a dual point, mechanical advance, 4 cylinder model. There is a spring loaded, adjustable piston with a felt end(oiled), that rubs on the edge of the spinning lower plate that holds the two centrifugal weights. Does anyone know what this is for? Does it provide some "drag" on the plate, or what??? Thanks
guam2250 is offline   Reply With Quote
Old 11-27-2019, 02:52 PM   #2
J Franklin
J Franklin's Avatar
Talking Re: Model A Mallory distributor, model K, type 13
Curiosity killed the cat! A model A brought him back.
Old 11-29-2019, 09:56 AM   #3
marko39
Default Re: Model A Mallory distributor, model K, type 13
Sounds like a vacuum brake as used on the V8 Dist. Does Dist. have a vacuum port?
marko39 is offline   Reply With Quote
Old 11-29-2019, 05:43 PM   #4
guam2250
Hello. Yes, there is a brass elbow that could be for vacuum. My only thought was some sort of brake. What is the function of this?? Thanks for getting back to me. - Mark
Old 11-29-2019, 05:57 PM   #5
rotorwrench
rotorwrench's Avatar
It's for spark control. The brake slows the moving advance plate under low vacuum conditions to automatically retard the spark.
