Old 01-29-2020, 06:49 PM   #1
Ken/Alabama
Ken/Alabama's Avatar
Default Plug Wire Tubes
Got these plug wire tubes with only two holes facing the heads and one on the inside facing the intake. All the others I have has three holes facing the head . What gives?��
File Type: jpg 770E5572-C066-4565-914A-00B884782567.jpg (19.6 KB, 382 views)
Ken/Alabama is offline   Reply With Quote
Old 01-29-2020, 07:40 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Plug Wire Tubes
Schramm air compressor, perhaps? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-29-2020, 07:59 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
Maybe? DD
T5 W/TORQUE TUBE
Old 01-29-2020, 09:25 PM   #4
rustythumb
seems like the '42 distributor has 2 wires that have to cross over to the opposite side of the engine.? i don't understand why.
rustythumb is offline   Reply With Quote
Old 01-30-2020, 08:44 AM   #5
42merc
42merc's Avatar
These conduits are used with the "crab" dist cap, '42-'44.
The The firing order of the crab cap dictates that two wires must cross.
Most hot rodders do this at the cap & dispose of the conduits.
42merc is offline   Reply With Quote
Old 01-30-2020, 09:30 AM   #6
Kube
Kube's Avatar
The TRUE '42 conduits had a small metal tube that fit from one side to the other for the two wires to cross. The photo in the original post is NOT 42.
Old 01-30-2020, 10:05 AM   #7
42merc
42merc's Avatar
I've fussed with '42s a couple of times and have not seen a metal tube on the cross over wires, only a coated sleeve, like a small version of a head lite loom.
How about a part number for the metal tube ?
Old 01-30-2020, 11:11 AM   #8
Kube
Kube's Avatar
I'll try to get a photo. They are scarce. No doubt got tossed when the wires were serviced.
Old 01-30-2020, 01:08 PM   #9
petehoovie
petehoovie's Avatar
Under the hood 1942 Ford V8
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 01-30-2020, 02:55 PM   #10
Kube
Kube's Avatar
Pete, The 42 you've depicted does not have the correct plug wire tubes.
Old 01-30-2020, 04:25 PM   #11
35fordtn
35fordtn's Avatar
Mike I do not doubt you either, but all the NOS 21a tubes I have do not have a metal cross over (like the Lincoln’s had) local to me there is a super low mileage 42 4 door and it has a tar covered covering over the cross over wires but no metal shield. Page 5-9 of the clubs book states they had a braided heat shield... I’m confused
35fordtn is offline   Reply With Quote
Old 01-30-2020, 04:32 PM   #12
petehoovie
petehoovie's Avatar
Maybe you could take a picture under the hood of this "local" car?
Old 01-30-2020, 04:37 PM   #13
35fordtn
35fordtn's Avatar
I can next time I am around it it’s in Nashville a hour from me. I would not wish to use it as a sure fire example. I would like to figure out the confusion in my mind. I’m certain the tubes I have that are 21a are service parts
Old 01-30-2020, 05:14 PM   #14
Kube
Kube's Avatar
I am attempting to get near this car now.
Old 01-30-2020, 05:20 PM   #15
35fordtn
35fordtn's Avatar
Mike,
The metal tube thing makes since as the Lincoln’s have it, do you have a photo of them with the tube? Somewhere at home I have some photos of the local 42 I’ll see if I can find them as I’m not wanting to drive an hour for a photo.
Old 01-30-2020, 05:23 PM   #16
petehoovie
petehoovie's Avatar
Lincoln V12 with cross-over tube >
With the tube missing >
Old 01-30-2020, 05:25 PM   #17
deuce_roadster
deuce_roadster's Avatar
I have a number of NOS parts from a bought out dealership that were replacement parts from when Ford no longer accepted returns I think in the mid 50s.
Old 01-30-2020, 05:55 PM   #18
V8COOPMAN
V8COOPMAN's Avatar
I guess it's entirely possible that I am the confused one here, but whether there is an extra "crossover" hole on the opposite side or not, that still doesn't explain the need for the AWOL front hole for a plug wire to fire the front (#5) cylinder. DD
T5 W/TORQUE TUBE
Old 01-30-2020, 06:00 PM   #19
35fordtn
35fordtn's Avatar
As you can see I have my fair share of these exact tubes in question.
Old 01-30-2020, 06:24 PM   #20
35fordtn
35fordtn's Avatar
I looked in my 1944 Canadian parts catalog. It lists two different conduit versions for the 21A type cap..
21A-12280-B ---RH 21A-12281 --- LH and 21A-12110 Ignition cable conduit (this is obviously a crossover conduit, but it does not say if it is metal like the Lincolns or braided like the Early Ford V-8 41-48 book states) These are listed for 1942-44
It also lists
C31A-12281 --LH and C31A- 12280-B -- RH these are listed for 1944 only and obviously likely military
