Old 09-09-2020, 06:46 PM   #1
cowtown
Default Ford Clutch
Will a 1949 Ford clutch work in a Model A? Thanks Fordbarn
cowtown is offline   Reply With Quote
Old 09-10-2020, 11:07 AM   #2
katy
katy's Avatar
Default Re: Ford Clutch
Yes, with modifications!
Old 09-10-2020, 01:23 PM   #3
Jim Brierley
49-53 Fords used a 9 1/2" clutch (I think) and a different spline in the disc. The most commonly used clutch is the earlier 9" version, used in the late 30's and early 40's. Ford tractor clutches will interchange with these but don't have centfifugal weights that help grip at higher RPM's, not critical in stock A's. Some guys have been recently going to diaphragm clutches, mostly from Ford Ranger pickups, they are much smoother, and rarely, if ever, chatter. All require machining the wheel flat and drilling the proper bolt pattern on it.
Old 09-10-2020, 07:55 PM   #4
cowtown
Thanks Alot. I have a new in the box clutch I bought for a 49 shoebox I have but never installed it. I am now putting together a RUSTY 29 CC Pickup and am going to leave it rusty and thought I would use the clutch if it would fit but I will just buy the right one and be done with it. Thanks Again!!!
