08-21-2020, 07:57 AM | #1 |
Nu-Rex popout look alike ignition switch
Went to take my 28 leather back out and smoke starts coming out of the dash . Took dash apart nothing was fried but car wouldn’t start . Hot wired the switch and the car instantly starts . Made in China ignition switch let all its magic smoke out . Has anyone used a nu Rex switch ? Seems they are made in Akron Ohio .
Thanks guys ! https://www.nurex.com/pop-out-ignition-switch
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom |
08-21-2020, 08:30 AM | #2 |
Re: Nu-Rex popout look alike ignition switch
I can't say for sure the ones that Snyder's sells are Nu-Rex, but we have used them (the ones Snyder's sells) with no reported issues.
I know the voices aren't real but damn they have some good ideas! |
08-21-2020, 09:20 AM | #3 |
It does say in Snyder's catalog that their ignition switch is a "Genuine Nu-Rex".
Which brings up something I wish the vendors would do more often is state who the manufacturer is on a part so I can determine if I want to buy it or not. There are some good manufacturers and there are some not so good ones that I try to avoid and will return if received. Nu-Rex makes an ignition switch with an accessory terminal that may be a solution to a question in another thread.
Ruth "Sometimes you really DO need to read the whole thread" Last edited by Ruth; 08-21-2020 at 09:32 AM. |
08-21-2020, 09:51 AM | #4 |
Flop, -good to see you back man!! Post up some pix of what you are working on!!
I would venture a guess the Ammeter is what is faulty. As for the Nu-Rex switch, they are very good quality. You won't go wrong with one of those. |
08-21-2020, 09:58 AM | #5 |
I have used the Nu-Rex switch for several years now with no problem. Looks good in the instrument panel, very similar to the original pop-out. I've had problems in the past with several of the cheaper switches; the Nu-Rex is worth the higher price.
Glad to see you posting again, Flop. W. Michael |
08-21-2020, 10:15 AM | #6 |
On some old reproduction instrument panels, the back of the switch contacts the gas tank because the shape of the panel is wrong. This is clearly not good. The Nu-Rex switch has a mounting collar held by a very small set screw. You can loosen the set screw and turn the mounting collar 1/2 turn or 1 turn or whatever you need to have the switch not contact the gas tank, then tighten the set screw back up and carry on. I like this adjustability that is built in. I also put a couple of strips of electrical tape on the gas tank behind where the switch will mount, as added protection against the switch contacts touching. No one sees the tape.
08-21-2020, 10:26 AM | #7 |
Thanks guys !! Brent working now on our farm house from the 1880s moved out of the city to the country . 7 acres now a 6k sq foot pole building etc etc .Haven’t worked on a car in about a year . Hopefully it will be fun again once I start messing with them again . I was burned out . That’s my 28 leatherback
08-21-2020, 10:29 AM | #8 |
Brent ...also does anyone make a good ammeter ?
08-21-2020, 10:41 AM | #9 |
I'm not Brent, but...
Not reproduction. You need to get a restored original. Thankfully they are available. .
08-21-2020, 10:51 AM | #10 |
Thanks Jim !! I’ll have to start looking for an original !
08-21-2020, 09:14 PM | #11 |
They are made in Mexico, but work great.
08-21-2020, 10:14 PM | #12 |
Flop: nice lookin car
08-22-2020, 06:48 AM | #13 |
On some old reproduction instrument panels, the back of the switch contacts the gas tank because the shape of the panel is wrong. This is clearly not good. Quote from Jim/GA
I switched to one of the uncommon brass made original Ford "A" 30-31 gauge panels. They are shallower then the steel ones and this has caused a lot of problems using the Nu-Rex popout switch. I've taped everything: the back of the switch, the gas tank, etc. I still get a short in the ignition if I tighten the top left gauge panel screw to tight. Bob-A |
