08-08-2017, 02:50 PM | #1 |
F4 steering box?
Hi guys I have a 1952 ford f1 with a steering box stamped 7rt-3550. Ordered a f1 pitman arm 8c-3590 which is too small. Is this a f4 steering box which would use a 7rt-3590 pitman arm? If so, do you know where to find one. Thanks,Joe
08-08-2017, 11:44 PM | #2 |
Re: F4 steering box?
http://joblotauto.com/
steering box should be 7RC in the F1, bigger trucks used 7RT box. They're easier turn (better ratio) so some were swapped into pickups. Joblot automotive should be able to help you - at least they were great in the past for truck parts. |
08-09-2017, 07:35 AM | #3 |
I thought Joblot closed their doors?
08-09-2017, 07:39 AM | #4 |
Chuck's Trucks, I believe they are located in Conn purchased a lot of truck stuff from Joblot when they closed
08-09-2017, 10:17 PM | #5 |
