Old 04-11-2021, 06:31 PM   #61
FlatheadTed
FlatheadTed's Avatar
Default Re: How to repair damage to a deck
My two cents .Like the others I would avoid any heat related solutions , or if so just solder . JB is probably a good solution but you could consider a high temperature silicone. The gauge is shallow and its on the inlet valve the colder of the two and would have the gasket go into it some what . Dodge has the suggestion that you could most likely feel the most confidence with , decking a block is common on a rebuild these days
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 04-12-2021, 06:39 AM   #62
JWL
My solution would likely only be appropriate for me to apply. I, therefore, chose to not comment.
JWL
JWL is offline   Reply With Quote
Old 04-12-2021, 10:38 AM   #63
Will D
Will D's Avatar
JWL
You just did comment tho, now you've planted a seed. Are you really gonna leave us hanging now?
Sometimes, ingenuity gets in the way of sense and sanity.
Will D is offline   Reply With Quote
