Old 04-05-2021, 03:00 PM   #21
alexiskai
alexiskai's Avatar
Default Re: Plug connector options?
Correct, this mapping already exists and is one of the reasons I bought the Nu-Rex device. At this point I don't have a reason to think it's not working as designed. If I start to get timing issues then I'll look into mapping my unit.
Old 04-10-2021, 12:11 PM   #22
alexiskai
alexiskai's Avatar
Update: The Model B connectors are also not quite long enough. But there's enough length that I can cut them asymmetrically and have a friend help me solder them together to make two long and two short connectors.
Old 04-11-2021, 11:17 AM   #23
Chris in WNC
Chris in WNC's Avatar
when the late Roger Kauffman was driving from OH to CA in the 1990s he lost a plug connecter somewhere out in the boonies.
He cut a length of barbed wire from a derilect fence row and fabricated a connector out of it.
Worked fine and looked so cool he left it in place after returning home......
our next Model A is out there in the unknown......
Chris in WNC is offline   Reply With Quote
Old 04-20-2021, 09:19 PM   #24
alexiskai
alexiskai's Avatar
Well, this sort of worked. 3 out of 4 of the soldered connectors are holding so far. One snapped and was too damaged to be put back together at the required length, so I made a wire.
I dunno, these don't look as good as I'd hoped. I think I'll make some wires instead. Maybe I can use the red-on-black Model T spark plug wire and terminals.
Old 04-21-2021, 12:15 AM   #25
Y-Blockhead
Y-Blockhead's Avatar
Your plug connectors should not be touching the distributor body anyway. Any moisture or carbon tracking would cause a misfire. #2 & #3 should be longer.
Old 04-21-2021, 12:22 AM   #26
alexiskai
alexiskai's Avatar
Yeah, it was worth a try but this is not a solution. I've ordered some 8mm Model T wire and the brass Model T terminals from Snyder's. I think I can make some connectors that resemble their '26-'27 plug wire kit. Plus this will give me a chance to practice soldering on something that's not a radiator.
Old 04-21-2021, 12:31 AM   #27
Y-Blockhead
Restoration Supply Company has a whole page of Vintage Spark Plug Terminals, if interested. Page 3 of their catalog. https://restorationstuff.com/shop/#fb0=5
Old 04-21-2021, 12:40 AM   #28
alexiskai
alexiskai's Avatar
RSC is too pricey, the brass terminals should work just fine.
The main problem I have to solve is that the spade terminal on the stock plug connector relies on spring action to work – the connector pushes the terminal against the distributor insert, which holds it in place. A wire won't push, it just hangs. So I need to take those ring terminals and form a slot in them like a keyhole, so they'll go over the insert and then lock into place.
Old 04-21-2021, 12:46 AM   #29
Y-Blockhead
I think you may see an end that clips on in the RSC catalog, pricey or not.
Old 04-21-2021, 12:51 PM   #30
alexiskai
alexiskai's Avatar
I saw that one, but it makes me nervous. I want something with a closed end.
Edit: Posted my solution to this problem in another thread
https://www.fordbarn.com/forum/showthread.php?p=2019342
