Old 03-16-2021, 08:29 PM   #1
Bob from Northport
Bob from Northport's Avatar
Default AA truck brake switch question
Working on an AA truck in the shop. Replaced the wiring harness in the truck.
Everything is working now except the brake lights. Tester on the switch indicates the switch is not working, no continuity. There is a spring assembly that pulls on the back of the switch when the pedal is pushed. Can anyone advise how the spring holder on the opposite end of the spring is adjusted to allow the switch to work properly.???
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 03-16-2021, 08:38 PM   #2
1crosscut
1crosscut's Avatar
Default Re: AA truck brake switch question
You can loosen the two bolts holding it to the transmission tower and move the body of the switch. Perhaps that will be enough to allow it to activate. If not you will most likely need to pull the top cover off to see what is amiss inside.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 03-16-2021, 08:54 PM   #3
Bill Cilker
Bill Cilker's Avatar
Are you working on a 28-9 AA truck or a 30-31 AA truck?
Bill Cilker, Jr
Unrestored 190A Victoria
45B, 160B & 189A
Victoria Association President
Bill Cilker is offline   Reply With Quote
Old 03-16-2021, 09:02 PM   #4
Bob C
There were two types used for 1930-31 trucks, none with a spring.
Old 03-17-2021, 07:58 AM   #5
Bob from Northport
We are working on a 31 AA Truck. There is a spring attached to the brake switch, not a chain like in the photo. The other post referring to the tower is not this truck. Snyders shows a spring in their catalog. Just wondering about adjustment of the bracket on the brake rod.
Bob from Northport
Northport, Michigan
Old 03-17-2021, 11:11 AM   #6
Bob C
Here is a picture from the parts book of AA-13511.
Old 03-17-2021, 11:14 AM   #7
Bob C
There are good pictures on pages E-18 and E-19 of the Judging Standards.
Old 03-17-2021, 06:22 PM   #8
Bob from Northport
This is what we have under the truck after we cleaned it up and installed a new switch. Just wondering about the adjustment of the new switch. Somewhere is the life of this truck someone changed the set up.
Bob from Northport
Northport, Michigan
