03-01-2021, 03:34 PM | #1 |
Oil hole on the back of the block
Is the oil hole on the back of a V8 block 1/8 NPT Thread????
03-01-2021, 03:54 PM | #2 |
Re: Oil hole on the back of the block
the two ports for the sending unit, and the filter line are 1/4" npt, if thats what you are lookin for
03-01-2021, 03:56 PM | #3 |
I think iy 3/8 NPT? but my memory is not very good these days.
Gramps |
03-01-2021, 04:03 PM | #4 |
"The" oil gallery plug should be 1/4 pipe.
03-01-2021, 04:22 PM | #5 |
Yyyeessss, exactly what I was looking for!!! THANK YOU....now I can get every thing I need before I start so I don't have to stop and run to the parts store in the middle of the job!!!!!! Only thing is "mine" only has one, not two.....the oil sender AND the oil filter line are coming out of ONE brass tee block on the back of the block!!! SO now I have to figure how to get my mechanical gauge into the loop!!!
03-01-2021, 07:50 PM | #6 | |
Use this 4-way with a "close", or short nipple into the block. DD eBay Item #361468769649 as an example....$7 bucks! |
03-02-2021, 07:45 AM | #7 | |
Exactly what I was looking for...Thanks V8Coupeman.....AND there IS two holes......I just couldn't see under the sender and with all the "grime" on the back of the engine. Thanks again ALL for your help!!! |
03-02-2021, 08:20 AM | #8 | |
03-02-2021, 08:33 AM | #9 |
