02-18-2021, 05:10 PM | #1 |
1940 Pickup Front Fender Bracket hole Location
I am using a 42-47 cab and there are no holes for the cowl fender brackets. The reveal is there but that’s it. Looking for a hole size and a location within that small reveal. If it’s in the center that’s fine - Abby pics or I for woukd be appreciated ....
Thanks for any help you can give .. |
02-18-2021, 05:44 PM | #2 |
Re: 1940 Pickup Front Fender Bracket hole Location
Tom, It seems as if I never take enough photos. I'll probably never learn to do "it" different. I have attached two photos that might get ya a little closer...
Sorry that's all I can help.
02-18-2021, 06:05 PM | #3 |
5/16" square for a carriage bolt. Its usually booged up on 40-41 cabs from wear tear and accidents. I have re- enforced it in the past because the square on the carriage bolt is thicker then the sheet metal
02-18-2021, 06:17 PM | #4 |
^^ Skid is right. Often boogered up, probably some fatigue. It is in the centre of that dimple (as far as I can tell).
Do you have the little brackets? They only go on one way round. Mart. |
02-18-2021, 06:37 PM | #5 |
Thanks gents - I have what I need ....
02-19-2021, 08:39 AM | #6 |
02-20-2021, 12:33 AM | #7 |
I realize that you've got it, but this still MIGHT help ya...the BOTTOM pics! DD
02-20-2021, 11:26 PM | #8 |
My cab was a virgin and Han no holes one’s either side but the flattener area location is. As Mart said, I drilled a hole dead and the middle by lining up a similarly sized washer. I used some rear fender bedside bolts, flat side out, square portion in the bracket itself, to bolt them in place. I will see how that works out ....
