09-28-2021, 01:43 PM | #1 |
Windshield Glass Removal
While trying to remove a windshield glass to be used as a template the glass cracked. The old sealant would not release.
The restorer asked me if I had any ideas. I suggested talking with his local glass supplier, or maybe a solvent like lacquer thinner. Trying the lacquer thinner just cracked the glass. I found this product, which may be the magic he needs. Quick Release Agent, in a 14 ounce spray bottle. Specifically used to release the glass from old sealant. Anyone tried this, or have other suggestions. The windshields I worked on were both delaminated, and the bedding was not adhered to the glass. I Never asked a glass supplier what they do. |
09-29-2021, 07:32 AM | #2 |
Re: Windshield Glass Removal
Bob-As I struggled to separate the frame from the glass, the glass broke. I discovered that it is not laminated safety glass, so no great loss. New frame is on order, and local shop says they can fit new glass to frame. My only concern is about how to bed the glass. I don't want to be a PIA and tell the shop how to do it, but want to be sure they use the right material. Might they use 'modern methods' that are as good as using the bedding sold by our vendors?
09-29-2021, 11:01 AM | #3 |
My experience doing a handful is what you can view in the YouTube series I made.
https://m.youtube.com/watch?v=uW_RxKdCoxs Go to the mafca site to pull up all 6. I used two types of Imbedding from our suppliers. If you are going for a restoration the canvas backed was used. No other sealant to my knowledge. You will have to discuss this with your local shop. Why did you order a new frame? Pitted original? |
09-29-2021, 11:22 AM | #4 | |
09-29-2021, 11:33 AM | #5 |
Until I removed the glass I could not see the condition in the glass channels on my frames.
Epoxy can only do so much. |
09-29-2021, 11:34 AM | #6 |
The result is a perfectly sharp and straight edge of the butyl tape which ends exactly with the windshield frame. The only downside is that the cutting and peeling takes quite some time. |
