08-13-2021, 12:11 AM | #1 |
Replacing the pedal shaft
Here is how I replace the pedal shaft.
https://m.youtube.com/watch?v=SUQM4_p9kn8 |
08-13-2021, 07:26 AM | #2 |
Re: Replacing the pedal shaft
Thats neat but how to do it with bell housing on the engine?
08-13-2021, 12:38 PM | #3 |
As stated in the YouTube, problems trying to do in situ. Getting access, designing a mechanical device, ignoring the repair of the throw out shaft, PITA!
Ignoring inspection of rest of drivetrain, and the great unknowns, all lead me to the methods I used out of the vehicle. |
08-13-2021, 12:53 PM | #4 |
I would discourage anyone from attempting to replace a pedal shaft with the bell housing in the car. There is a good chance you will paint yourself into a corner. If the pedals are that sloppy, replace the bushings in the pedals and wait unit you have to replace a clutch and then with the bell housing out of the car, replace the pedal shaft along with the clutch release shaft and install new bushings in the bell housing.
Tom Endy |
08-13-2021, 01:18 PM | #5 |
Thanks for your advice Tom, you have been at this a long time.
08-13-2021, 02:27 PM | #6 |
08-13-2021, 04:11 PM | #7 |
I did a complete tear-down of my coupe, and upon removing the pedals saw significant wear on the shaft from both pedals. However, the bushings showed no sign of wear. I replaced both shaft and bushings. With bell housing on the bench, removing the shaft pin took some serious effort, but after that the shaft slid out easily--no need for Bob's well-designed threaded pusher.
