Old 09-09-2016, 03:25 PM   #1
rudvirus
rudvirus's Avatar
Default Dam radiator went out
So I am crushing down the road and the dam metal line that goes off the back of it decides to break off. It shoots fluid everywhere big old white smoke. Someone even called the fire department thinking it was on fire. The question is can it get get fixed or do I need to by a new radiator?
rudvirus is offline   Reply With Quote
Old 09-09-2016, 03:30 PM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: Dam radiator went out
Which metal line???
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 09-09-2016, 03:40 PM   #3
Marshall V. Daut
If you mean the overflow tube, it can be soldered back in place. If you mean the neck on the upper tank where the upper hose fits, that, too, can be soldered back. But make sure you take the radiator to a sympathetic shop that understands how to do this. The lousy radiator shops staffed by Gen-x losers will just try to sell you a re-core or a whole new radiator. THAT'S where they make their big bucks, not from re-soldering.
Marshall
Old 09-09-2016, 04:10 PM   #4
C26Pinelake
A picture of metal line you are referring to please. Wayne
C26Pinelake is offline   Reply With Quote
Old 09-09-2016, 04:10 PM   #5
Tiny
Tiny's Avatar
Marshall
Easy Now Grandpa!!!
That's my Generation and I've soldered and overflow back on.
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 09-09-2016, 04:17 PM   #6
rudvirus
rudvirus's Avatar
Yeah it's the overflow tube. When there was nothing but white smoke pouring out I couldn't really tell where the leak was. Now here's the question why does it over heat so bad then. I noticed it when I parked it was coming out of the same tube below lol before it broke.
Old 09-09-2016, 04:23 PM   #7
Tiny
Tiny's Avatar
Plugged radiator tubes. Do some searches on cleaning out rust and grease
Blackwall Panthers
Nor Cal chapter
Old 09-09-2016, 04:49 PM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
If that overflow pipe had a crack or rust hold on the part inside the upper tank, then it could have been draining off coolant until the block overheated. It is a relatively easy fix to solder a new tube in place. Hopefully you don't have a lot of plugged radiator tubes.
Old 09-09-2016, 05:14 PM   #9
nhusa
nhusa's Avatar
Originally Posted by Tiny View Post
Easy Now Grandpa!!!
Don't get your diaper in a bunch and it is obvious that you are an outsider to the Gen Xs.
Be careful about which generation you identify with.
I was in the 50's and 60's and actually remember part of it.
nhusa is offline   Reply With Quote
Old 09-09-2016, 05:18 PM   #10
rudvirus
rudvirus's Avatar
Well I called Bert's and told him what's going on and I already tried unplugging the radiator a few times and it's not working. So I ordered a new one. It needs it anyways.
Old 09-09-2016, 05:22 PM   #11
C26Pinelake
How fast is " crushing " ? Wayne
Old 09-09-2016, 05:27 PM   #12
Mitch//pa
Good move::the last thing ya want to do is keep cooking the motor
Old 09-09-2016, 10:32 PM   #13
tbirdtbird
or coking the motor
'31 180A
tbirdtbird is offline   Reply With Quote
Old 09-09-2016, 10:32 PM   #14
rudvirus
rudvirus's Avatar
Yeah I saw the pipe were the drain is and there was a leaf and other debris in there really bad do not know that even got in there. Maybe something my grandfather forgot to do something don't know but its cleaned out now.
Old 09-10-2016, 03:48 AM   #15
C26Pinelake
How fast were you driving Wayne
Old 09-11-2016, 09:30 PM   #16
31 Woody
31 Woody's Avatar
Afraid to comment...I'm a Gen X (1966). Mine broke or rusted off, I took the radiator to a radiator shop run by someone much older than me. In the end, I should have gone somewhere else or fixed it myself!
Have it repaired, but get the radiator cleaned out while its apart!
Experience is a cruel teacher. It gives the exam first, then the lesson.
31 Woody is offline   Reply With Quote
Old 09-11-2016, 10:08 PM   #17
Tom Wesenberg
About 25 years ago I removed the tank on one of my Studebaker radiators and cleaned the tubes and straightened the fins. It took some time, but wasn't too bad a job. I kept a blow gun in one hand and a small flame in the other. Heat the solder and blow it away. Just keep going around until it's all blown away, then lift off the tank and start cleaning.
Old 09-12-2016, 09:48 AM   #18
John Duden
John Duden's Avatar
Originally Posted by tiny View Post
easy now grandpa!!!:d:d
that's my generation and i've soldered and overflow back on.
x2!
John Duden is offline   Reply With Quote
Old 09-12-2016, 10:23 AM   #19
Tiny
Tiny's Avatar
Diaper in a bunch...
I usually just tell people I look good for 80
Blackwall Panthers
Nor Cal chapter
Old 09-12-2016, 11:04 AM   #20
H. L. Chauvin
"So I ordered a new one. It needs it anyways."
Time to celebrate ......... so many people are never fortunate enough to discover life's agonizing problems ....... nothing like a happy ending to one's struggles.
Cost? So what, just paper money vs. enjoying riding in a "cool" Model A.
H. L. Chauvin is offline   Reply With Quote
