01-19-2021, 01:34 PM | #1 |
Changing color of frame
I bought a restored 1 1/2T chassis ,complete except for the engine.
The color is silver gray and I want to paint it black. It appears that the metal was blasted as the pitting is not too deep and very clean. I tried rubbing a remote area of the paint with laquer thinner,brake fluid and carb cleaner. It was untouched. Any suggestions how to overcoat this paint ??? |
01-19-2021, 02:59 PM | #2 |
Re: Changing color of frame
Sounds like your frame may have been powder coated by the resistance you are finding trying to remove the finish. If you determine this, I have scuffed the surface with a DA with 120 grit and repainted it with enamel which held up very well.
01-20-2021, 01:40 AM | #3 |
To clarify: all chassis and running gear parts have been painted individually,
before assembly. |
01-20-2021, 12:33 PM | #4 |
Just paint it as Krylon32 recommends if you wan't it a different color. You nor the factory needs or did paint things separately.
01-20-2021, 12:44 PM | #5 |
Use a high quality etching primer and then then paint it.
Call Eastwood and see what they sell. |
01-20-2021, 01:13 PM | #6 |
01-20-2021, 01:15 PM | #7 |
Could the coating be Imron? I heard that stuff is really hard.
01-20-2021, 01:32 PM | #8 |
Or could be PoR 15, maybe KBS Rust Seal. I have used the Rust Seal on sandblasted transmission parts. Once cured, it is hard. Sand paper just scuffs it enough for their top coat.
I dig coal, which provides motivation for EVs. |
01-20-2021, 11:00 PM | #9 |
Or...re-sandblast the frame; no need to remove the coating that's on there, but sandblasting will provide a good 'tooth' for your desired paint system to adhere to.
01-22-2021, 08:15 AM | #10 |
Here is an approach. First determine what you would like to pain it with. Take a small part off the chassis and scuff it with sandpaper and paint it. If it looks ok and appears to have stuck you should be ok. I have doubts about a truck frame that big being powder coated but I could be wrong.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
01-22-2021, 10:15 PM | #11 |
[QUOTE=Frank Miller;1976711]Here is an approach. First determine what you would like to pain it with. Take a small part off the chassis and scuff it with sandpaper and paint it. If it looks ok and appears to have stuck you should be ok. I have doubts about a truck frame that big being powder coated but I could be wrong.[/QUOT
That is a sound idea.
