Old 04-20-2021, 12:32 PM   #1
Ford_Freddie
Default Original Intake Manifold
Hello, my Intake Manifold is cracked. A vendor in the USA offers me a good original one. Is that a good idea or should I wait for a new one. The new manifolds are out of stock until summer. Thank you for your help. Many greetings from Germany. Gernot
Ford_Freddie is offline   Reply With Quote
Old 04-20-2021, 12:47 PM   #2
alexiskai
alexiskai's Avatar
Default Re: Original Intake Manifold
Are you able to get the cracked intake apart from your current exhaust manifold? Sometimes they fuse together with age and it's very difficult to remove one without damaging the other. Worth looking at before you decide to buy a new intake by itself.
Old 04-20-2021, 12:57 PM   #3
Ford_Freddie
Thank you alexiskai. I don't know. I will try to take them apart.
Old 04-20-2021, 12:58 PM   #4
1930artdeco
1930artdeco's Avatar
As long as the new one doesn’t have cracks in it then go for it. That is assuming you can’t fix your other manifold.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 04-20-2021, 12:59 PM   #5
1930artdeco
Mike
1957 Country Sedan
Old 04-20-2021, 01:05 PM   #6
Ford_Freddie
Thank you Mike.
Old 04-20-2021, 01:11 PM   #7
abachman3
abachman3's Avatar
When you get your new one, bolt it up with the exhaust manifold and place a steel ruler across all of the flanges. Make sure that they are ALL on the same plane, or the setup needs to be ground/machined flat.
abachman3 is offline   Reply With Quote
Old 04-20-2021, 02:43 PM   #8
Bill Cilker
Bill Cilker's Avatar
Freddie
There are basically 3 different manifolds, one with our a vacuum hole (BOP-6/29), one with a high vacuum hole (7/29-7/30) and the last with a lower vacuum hole (7/30-EOP).
Also, be careful that the thickness of the mounting flange is correct. When an intake manifold is bolted to a exhaust manifold, they should be machined so that the mounting surface is flat across them.
Bill Cilker, Jr
Unrestored 190A Victoria
45B, 160B & 189A
Victoria Association President
Bill Cilker is offline   Reply With Quote
Old 04-20-2021, 03:21 PM   #9
Big hammer
Several good suppliers here in the USA, try another one?
get a bigger hammer tap done
Old 04-20-2021, 05:16 PM   #10
Gene F
Gene F's Avatar
I have a 1928, and it has zero vacuum pots.
Gene F is offline   Reply With Quote
Old 04-21-2021, 02:26 AM   #11
Ford_Freddie
Thank you all.
