03-13-2021, 08:21 PM | #1 |
generator case question
Rebuilding a spare generator for an 8BA. Can the inside of the case and coil shoes be painted or do those need to be shiny metal against the armature?
JB |
03-14-2021, 04:49 AM | #2 |
Re: generator case question
They can be painted, use insulating paint, do not put it on to thick and check to make sure amateur does not rub shoes.
03-14-2021, 06:06 AM | #3 |
Use any good metal primer paint, and dont layer it to thick between the pole shoes and the casing. Need to maintain armature clearance with pole shoes. Regards, Kevin.
03-14-2021, 11:05 AM | #4 |
