01-08-2021, 10:19 PM | #21 | |
Re: What is this truck?
3/4 tons still had wide fives in '40
Making the simple complicated for over 30 years. |
01-08-2021, 10:19 PM | #22 |
Denny, I had a 1941 3/4 or 1 ton back in 1973 that had wide 5 wheels.
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
01-08-2021, 10:23 PM | #23 |
tubman, I can't answer your question personally, as these Ford Panel Trucks were never available in Australia. You would have to ask someone in the USA who is more familiar with this model. However, if you look at this Illustration of the 1940 Ford 3/4 Ton Panel from the original Sales Brochure, it does appear to have the same "wide-five" wheels that the School Bus that is on display in the Early Ford V8 Foundation Museum has? What do other people think? |
01-08-2021, 11:35 PM | #24 |
The Ozzie trucks use 38 style doors, whereas the American trucks use the 'jailbar' style doors. Look at the swages..
01-08-2021, 11:47 PM | #25 |
3/4 tons used the wide fives, on a 122" wheelbase. Only for a couple years. Never seen one in person. Only thing more oddball would be if it had a 4 cyl tractor engine. So now we have a large, long wheelbase truck with big fender openings and little tires and large interior volume that can't climb a hill. It was short lived for a reason.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
01-08-2021, 11:54 PM | #26 | |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) Last edited by GB SISSON; 01-09-2021 at 12:18 AM. |
01-09-2021, 01:00 AM | #27 |
the wide 5 truck hubs and bells were the basis of the early dirt track cars with a QC rear
01-09-2021, 05:07 AM | #28 |
Ford Australia built quite a few of these 1940 Open Cab Pick-ups. Many were used by the Army in World War II. I saw this survivor many years ago, but it's fate is unknown. I don't know if it has been lost or saved? |
01-09-2021, 08:27 AM | #29 |
Would look even better with the Marmon-Herrington underpinnings.
I dig coal, which provides motivation for EVs. |
01-09-2021, 09:04 AM | #30 |
1940 & 1941 Trucks came in 4 "sizes" look at the wheels.
Small pickup looked like a standard car, 112" wheel base 16" 5 on 5 1/2" wheel hub caps same as cars. 3/4 ton looked like the ones in these pictures, 122" W.B. 16" wide 5 wheels & hub caps. Tonner has same look, 122" W.B. 17" split rims and hub caps specific to them. 1 1/2 ton same look Various W.B. 20" split rims, no hubcaps, dual rear wheels. The big difference in all of these is size of the brakes to match weight rating. |
01-09-2021, 01:53 PM | #31 |
"Tonner has same look, 122" W.B. 17" split rims and hub caps specific to them."
To clarify a misconception the 1940 17" Tonner Rims used a Continuous Locking Ring to hold the tire to the rim as opposed to the Split Rim type. |
01-09-2021, 03:43 PM | #32 | |
Never knew the actual term for the one piece ring type wheels. Always referred to any 2 piece rim as a split rim (with the exception of widow makers) Either way they are both a PITA to mount/dismount. IMO. Back in the mid '70's I worked with an old guy (he remembered when a lube job included treating the rubber coating on the running boards) who showed me how to mount/dismount them. Even with the correct tire tools the shop had and his assistance I never was able to change a tire as easily as he could and he had me by 40 years or more.
01-09-2021, 03:44 PM | #33 |
Here is a picture of a restored Australian 1940 Ford Open Cab Pickup, similar to the one that I added in Post 28. This one is from down south in Victoria. |
01-09-2021, 03:53 PM | #34 |
01-09-2021, 04:41 PM | #35 |
To answer MGG's question:- This illustration of an Australian 1940 Ford Heavy Duty Truck showing Quarter Windows - is from the original Australian Ford Truck Sales Brochure. |
01-09-2021, 05:10 PM | #36 |
1940 for sure.
01-09-2021, 06:18 PM | #37 |
Here are two pictures of Australian 1940 Ford Vans which are illustrated in a Booklet on 1940 Fords published by Ford Australia. Notice that these Vans also have Quarter Windows. Also notice the different full length body moldings that have three strips, which is different to the American body. Also notice that the 15-18 cwt unit has what appears to be Wide Five Wheels. |
01-09-2021, 06:29 PM | #38 |
Did the 1940 Australian Big Trucks have a cowl vent? I can’t tell from your photos. That might explain the use of 1/4 windows on trucks made in Australia.
01-09-2021, 06:42 PM | #39 |
Australia 1941 Ford Open Cab Pickup. Notice that it does not have V8 Pressings on the sides of the Hood, also it has wide trim on the Hood, thereby making it a 1941 model. |
01-09-2021, 06:48 PM | #40 |
