08-07-2018, 11:16 AM | #1 |
Blemished wide white tire
I just purchased 4 wide white wall tires, and one of them has 3 brown streaks on the white side wall. Have anyone had this problem , and what did you do to get them out. I've use all kinds of tire cleaners to no end and they won't come off. Al
08-07-2018, 11:18 AM | #2 |
Re: Blemished wide white tire
Kiwi Liquid Shoe Polish
08-07-2018, 11:26 AM | #3 |
If Westley's "Blech-Wite" won't do it, I can't help ya.
08-07-2018, 11:27 AM | #4 |
I use Bleche Wite, available in hardware, big box and auto parts stores. Spray it on, let it sit for a minute or two and use an old sponge with water to rub off the dirt, stains etc. Then spray off with a hose. Might take a few times to clear those stains. Use on a dry tire. Cleans up black walls,too.
08-07-2018, 11:43 AM | #5 |
Those streaks are probably from brake dust that might have been wet and slung around when driving. I get them mostly on the front with disc brakes. I use Bleche-Wite with a small scrub brush and they come out.
08-07-2018, 11:52 AM | #6 |
Heres a link: http://lasteffortgarage.com/cleaning-products.html |
08-07-2018, 12:11 PM | #7 |
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 08-07-2018 at 12:44 PM. |
08-07-2018, 12:41 PM | #8 | |
08-07-2018, 01:16 PM | #9 |
Sometimes those stains are caused by storing tires on top of each other with the black wall side down against the white wall. Long term storage they should be separated with paper or cardboard.
08-07-2018, 01:26 PM | #10 |
Simple Green and a ScotchBrite Pad. Magic Eraser works too.
08-07-2018, 01:58 PM | #11 | |
I just purchased 5 Firestone wide whites from Summit, from Coker tire and they have big warning labels on them saying that storing them with black side on white side will make a permanent stain on the white side. Hope you get it off. |
08-07-2018, 02:14 PM | #12 |
08-07-2018, 02:41 PM | #13 |
scrubbing with a brillo pad works as well...
08-07-2018, 03:12 PM | #14 |
i've used soft scrub for tough spots before. works well with a tooth brush.
08-07-2018, 05:05 PM | #15 |
Did you purchase the tires new or used?
08-07-2018, 05:44 PM | #16 |
Many times I have used laquer thinner on a rag to make rubber items look new.
08-07-2018, 06:27 PM | #17 |
08-07-2018, 06:45 PM | #18 |
IMHO: The current version of Bleche-Wite is NO way near as good has the original version made by Wesley's, this new crap made by Black Magic is a watered down version of the original and to me, a waste of $, YMMV
Regards, Todd 1936 FORD Tudor Slantback "cajunhotrodder" on instagram/youtube |
08-07-2018, 08:09 PM | #19 |
be careful with the brillo pads as to much pressure & you will put scratches in the whitewall.
08-07-2018, 08:26 PM | #20 |
Try Castrol Super Clean and an SOS pad.
