Old 04-22-2021, 04:46 AM   #1
Jacques1960
Jacques1960's Avatar
Default Shift lever position / modification
The driving experience in my 38 is generally superb; however, the shift lever is just too close to my thigh in the first gear position - at 6’5” and 20 stone, not much I can do on my end. Any non-destructive / easily reversed work arounds out there ? Thank you,
No job’s done ‘til it’s all done
Jacques1960 is offline   Reply With Quote
Old 04-22-2021, 06:03 AM   #2
Terry,OH
Terry,OH's Avatar
Default Re: Shift lever position / modification
Not easily reversed, the shift lever has to be removed and heated red hot at the base and bent slightly. It's not a hard job but would have to replace the lever with another to get it back to original.
Old 04-22-2021, 06:08 AM   #3
Mart
Mart's Avatar
It might be possible to bend it cold if you could position it suitably in a press. I suspect heating and bending will be easier.
Old 04-22-2021, 06:54 AM   #4
john in illinois
john in illinois's Avatar
I measured how much I wanted to move mine. I put it in a vise and clamped a piece of angle iron to indicate where I wanted to bend it.
I heated and bent it. Turned out just right
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 04-22-2021, 08:01 AM   #5
Jacques1960
Red wrench it is ! Thank you all.
Old 04-22-2021, 10:33 PM   #6
Pete
Pete's Avatar
Dull red is plenty of heat. Don't plan on power shifting with it afterward or it will bend. It will be ok for normal street use.
Pete is online now   Reply With Quote
Old 04-23-2021, 05:19 AM   #7
Kerk
I would check the slot and pin fit on the ball section of the lever. A rebuild of that area may solve your problem. Just worth a look to see how worn it is. DO BE CAREFUL TO NOT DROP THE PIN IN THE SHIFT TOWER !! jm2cw. kerk
Kerk is offline   Reply With Quote
Old 04-23-2021, 06:40 AM   #8
Jacques1960
...and you know about not dropping the pin because...
