#1 |
I am restoring a '54 F100. Looked at door hinges and access to the pillar 6 bolts or the access door on the door itself (6 bolts). It seems that the door bolts make an easier removal. Any advice out there? Thanks.
#2 |
Did the door bolts on my project. Makes it so much easier to reinstall too.
#3 |
If the doors fit good now, take some pics of the bolt locations on the door for easier reassembly.
#4 |
If you drill an 1/8th inch hole thru the door side of each hinge into the door before disassembly, you can use them to index the door into the original position when reassembling.
#5 |
