04-13-2020, 09:05 PM | #1 |
'30 Header question. Not letting visor fit.
Hi. Sandollar here. Been away for some time.
Installed header on my '30 coupe. But when installing sun visor cannot get the 2 screw holes on post to line up. The header sticks about 1/8" above header sheet metal cover. It looks like I might need to shave that 1/8" off where header is proud. Am I correct? Should the top of the header be even with the top of the header sheet metal cover? The Andrews book Vol. II ( 3-87) does not address this. Thanks in advance for any help given. |
04-14-2020, 07:21 AM | #2 | |
Re: '30 Header question. Not letting visor fit.
Unfortunately your situation is because your front roof rail (A-47235-B) is likely made incorrectly. Since I have not purchased a commercially made front rail in some time, I can't really help you with the exact location of the issue(s) with yours. I have given you the correct part number where you can order a print from Benson as soon as they re-open and make the necessary corrections to yours. |
