02-12-2020, 02:07 PM | #1 |
34 ford rear differential cage bearing grease
Trying to find the long fiber wheel bearing grease. It is recomendid for Cage roller rear end Bearings. Can anyone help ?? Thanks Stan
02-12-2020, 02:46 PM | #2 |
Re: 34 ford rear differential cage bearing grease
Try the Model T site ,or the Tram enthusiasts,
02-12-2020, 02:51 PM | #3 |
Mac Van Pelt sells it. vanpeltsales.com
02-12-2020, 02:54 PM | #4 |
Stan,
Are you still interested in condensers? I have gotten 2 empty PM's from you in the last couple of weeks. Sorry to hijack this thread, but I don't want to leave ya' hanging. Tubman |
02-12-2020, 02:55 PM | #5 |
Here' the grease that's used on 40 Fordd rear wheel bearings. I think 34 is the same.
https://www.google.com/search?q=sta+...hrome&ie=UTF-8 |
02-12-2020, 03:44 PM | #6 |
Unless you mean the rear wheel bearings which are roller type and within the hub. Then the question is valid. Mart. |
02-13-2020, 10:07 AM | #7 |
NAPA sells the Sta-Lube SL-3131 for the rear wheel hub bearings. If they do not have it on their shelf they can get it overnight, in most cases.
02-13-2020, 10:51 AM | #8 |
Sta Lube 3131 is used on these type bearings in the rear wheel hub, called rear wheel bearing. Looks like this:
https://www.speedwaymotors.com/Speed...yABEgJN9PD_BwE |
