Old 06-14-2017, 03:31 PM   #1
John cruzin 40
Default John Cruzin 40
Hi guys hope I can get some help , put in new brakes in my 1940 ford also new master, and wheel cylinders new hoses and bled it i cant get a hard pedal car won't stop.
John cruzin 40 is offline   Reply With Quote
Old 06-14-2017, 05:28 PM   #2
19Fordy
19Fordy's Avatar
Default Re: John Cruzin 40
Read through this thread. It tells how to adjust the brakes. Do that first. Do Not Let
the Master Cylinder run dry when you are bleeding.
https://www.fordbarn.com/forum/showt...leed+40+brakes
Also, buy Speed Bleeders so that you can make it a one man job when you bleed them. They work great. This thread tells you all about them. Buy the long ones mentioned in the thread.
https://www.fordbarn.com/forum/showt...speed+bleeders
Here's the correct sequence for brake bleeding.
https://www.fordbarn.com/forum/showt...heel+cylinders
Also, some wheel cylinders made off shore are incorrectly made.
Read about it here, then check yours out.
Make sure you have no leaks in the brake lines.
Last, but not least. The SEARCH function is your friend.
Old 06-14-2017, 05:32 PM   #3
40cpe
40cpe's Avatar
Deleted, 19Fordy covered it while I was typing.
40cpe is offline   Reply With Quote
Old 06-14-2017, 08:30 PM   #4
34fordy
34fordy's Avatar
Did you have the shoes arced to the drums? If not, you may have a very small contact area and thus very poor pedal and stopping efficiency.
34fordy is offline   Reply With Quote
Old 06-15-2017, 06:26 AM   #5
John cruzin 40
Thanks 19 forty the frist set I installed with Avery noligable friend 10 years ago he since has pass so i brought it to a shop not sure if they did it correctly but it doesn't stop thanks for your help
Old 06-15-2017, 08:32 AM   #6
19Fordy
19Fordy's Avatar
I doubt if "shops" today know how to work on old Lockheed brakes.
Old 06-16-2017, 05:07 AM   #7
John cruzin 40
I questioned him he seemed like he new what to do i guess i will have to check out the parts that was installed THANKS AGAIN JD
