07-14-2016, 01:07 PM | #1 |
electic inline fuel pump
hi dose anyone know where get an 6v pos. gnd. inline fuel pump for a 42 flat head A B john
07-14-2016, 01:17 PM | #2 |
Re: electic inline fuel pump
Carter makes one, (P4259) I am running in my '40, got it from my local NAPA store cheaper than the inner-Web. You will need a regulator.
07-14-2016, 01:26 PM | #3 |
thank you i was looking at the one just was not sure thanks again John
07-14-2016, 01:26 PM | #4 |
try www.rockauto.com , like buelligan mentions above, you will need a regulator.
Thank God this is only a hobby! |
07-14-2016, 01:33 PM | #5 |
thank you funrunr
07-14-2016, 01:58 PM | #6 |
http://www.macsautoparts.com/ford_me...d-mercury.html
Tommy |
07-14-2016, 02:01 PM | #7 |
thanks Tommy
07-14-2016, 03:26 PM | #8 |
07-14-2016, 03:35 PM | #9 | |
https://www.summitracing.com/int/par...0504/overview/ |
07-14-2016, 04:06 PM | #10 | |
07-14-2016, 04:27 PM | #11 |
I installed an Airtex E-8902 pump on my Ford. 6 volt. I installed it near the fuel tank with an On/Off switch under the dash. They are available at NAPA,Advance Auto Parts and other parts stores. About $45.00. Has been on the car for 3 years no problems. I use it to prime if the car has been sitting for awhile such as winter and to over come vapor lock.I believe it should not be used continuously with the mechanical pump. I say this in case you want this to run full time.
07-14-2016, 04:37 PM | #12 |
07-14-2016, 04:58 PM | #13 |
07-14-2016, 05:18 PM | #14 |
I've heard that some guys run 12v pumps on 6v and then don't have to use a regulator. Haven't tried it myself, but sounds like it might just work.
07-15-2016, 08:38 AM | #15 |
Thank you all for your input realy help full
07-15-2016, 08:42 AM | #16 |
I decided on airtex 8902 6v thanks again
07-15-2016, 08:55 AM | #17 |
Amazon sells airtex.
07-15-2016, 09:18 AM | #18 |
Got mine here. http://www.fifthaveinternetgarage.com/
10-28-2016, 09:13 PM | #19 |
Got the Airtex 8902 for my 59AB, to replace an ancient Bendix.
Seems to be overpowering the Ford 94; flip the toggle and it keeps on pumping. Carb is rebuilt & rechecked- all OK. Airtex says the 8902 runs at 3-3.5 PSI, and the FH prefers 2-2.5 PSI. Airtex recommended I use a regulator. Anyone have a suggestion for a specific regulator? |
10-29-2016, 12:52 PM | #20 |
Rock Auto has the best prices. I always like to be cost effective. [Cheap]
